Honor Magic V3
eddy0505
For those sets with weird notification issues/bank app issues, which shop you guys got from? Mine was dvtech local set warranty can register with eplanet.
mahcosg
I have no issue with ocbc though. The theme store has limited choices for icons as well.
NeonX
Any recommendation for outer screen protector?
few pages back someone link a shopee link for tempered glass screen protector that fits case, i ordered but still waiting for it to arrive, hopefully really can fit case
tellim
Cos my screen protector starting to peel off as I removed the original cover, the sticky tape pulled the edge also. Sickening.
zobrak
Hi!
I have done all of it. Battery optimization, App Launch, Gentle Notifications. etc. Still doesn't work. I have also uninstalled the apps and restarted the phone. still the same.
. Actually I also noticed some other apps have notifications, but doesn't vibrate too.
can you check if you have some other apps blocking notification?
check notification access settings, see which apps have been enabled
doki81
Mine also dvtech but no weird issue...cannot be dvtech give us fake local set bah..
NeonX
Probably conflict with some other apps that uses system permissions I guess. But weird if previous android phone no such problem
NeonX
Day 4 battery report
25% left with 5.5hrs screen on time. Smart battery capacity off, got improvement from yesterday. Plus more gaming done today. So far so good.
Computeron
I feel u... Then how now?
HUH.. Got meh?
doki81
HUH.. Got meh?
this imak de...
curved edge..that's why can use case on it..
https://s.shopee.sg/6ASUbdBp1Z
