tohchr
- Oct 7, 2004
I used this brand before. Not badusing benks
Eek... Looks like the one I bought from tb. Black boarder, stick the sides only. Screen didn't stick one right?
is it, nb i order liao leh hahaEek... Looks like the one I bought from tb. Black boarder, stick the sides only. Screen didn't stick one right?
This sp flex my front case.. Not gd one.
This sp got thickness.. U put on front case, will push ur case up abit. Also will eat ur screen abit due to its black boarder.is it, nb i order liao leh haha
What case are u guys using? Any magsafe case to recommend?
What sort of settings should I do there? There are only Android Auto, Google Play services, Honor Home, Android System Intelligences and Link to Windows. I just enabled them all.can you check if you have some other apps blocking notification?
check notification access settings, see which apps have been enabled
By default, there's no vibration for notification on mine.What sort of settings should I do there? There are only Android Auto, Google Play services, Honor Home, Android System Intelligences and Link to Windows. I just enabled them all.
Also did a factory reset on the phone, but still the same! No vibration for notifications.
Haha...I will know what @kaiser_11 is going to say, "I have also did that too and nope, still no vibration for notifications". Seems like all avenues exhausted and whatever advice members can give all given. All at wits end. Last resort is to seek Honor's tech assistance.By default, there's no vibration for notification on mine.
U need to go to setting, notification and status bar, scroll to that particular app, all notification, notification tone, vibration, select the type of vibration u want.
Hello! Nope. I actually managed to solve the problem! Thanks to @tohchr!Haha...I will know what @kaiser_11 is going to say, "I have also did that too and nope, still no vibration for notifications". Seems like all avenues exhausted and whatever advice members can give all given. All at wits end. Last resort is to seek Honor's tech assistance.
It is hard to fathom why majority having no issue except for his phone. Even after a factory reset and re-downloading the apps from scratch (assuming not restoring from backup) and still not working as intended. It cannot be replicated and seems to me that he might have a corrupted ROM of sort.
In what way is it not working?my HSBC app not working...anyone got same issue? :O
@tohchr
Yes for some odd reason I never thought of pressing the Notification Sound that is within each Notification settings. And the setting is just there. No vibration! So managed to switch it on. Not sure why it is switched off by default. Bugging me all day. But yes, all good now.
Sorry, I'm still playing around with the phone and settings. Coming over from Samsung, some settings are not the same. Thanks all for your patience and all the advice! And taking time to answer all my posts and questions.
the app kept restarting after i enter my biometric or password to loginIn what way is it not working?
Clear that app cache and restart your phone. Make sure permissions are all granted.
U clear the app cache also cannot? That means should have some conflict. Did u restore from an old phone?the app kept restarting after i enter my biometric or password to login
tried above but cant work, tried uninstalling and install, cant also :O
2 weeks again i able to access, today i cannot :/ keep restartingU clear the app cache also cannot? That means should have some conflict. Did u restore from an old phone?
My HSBC is fine. No issue2 weeks again i able to access, today i cannot :/ keep restarting
Are you able to log in if you are using hsbc app on honor v3?
