tcmean
- Aug 18, 2004
Not true.. I signed up end of August and already gotten the updateThe theory is SH rolling update according to sign up month. Now is up to Apr sign up![]()
Not true.. I signed up end of August and already gotten the update![]()
No, I don't. Still log in with password onlydo u have tplink ID? means the theory shifts to tplink ID![]()
Yup binded, signed up in AprTo those who already received the update @JT2008 @Gforce_Ti @sean29 @derekli @kindredSG
- Do you have TP-Link ID and bind the router to your ID?
- When did you sign up for 10G plan?
Looking to see why I haven't got the update on mine
I check also don't have new firmware updateStrange La. I try to check for new firmware but no update at all.
Hmm... possible cos that will tie to public IP address range. So @JT2008 @Gforce_Ti @sean29 @derekli @kindredSG @tcmean which area are you at?When I was calling with the hub trooper when my router bricked, it seemed like they knew what was happening to the router. Perhaps the FW rollout is pushed by starhub according to subscribers residential zones maybe?
Sengkang area, but I have 2 routers, only one has been upgraded.Hmm... possible cos that will tie to public IP address range. So @JT2008 @Gforce_Ti @sean29 @derekli @kindredSG @tcmean which area are you at?
Bukit Batok West Area.Hmm... possible cos that will tie to public IP address range. So @JT2008 @Gforce_Ti @sean29 @derekli @kindredSG @tcmean which area are you at?
There goes that theorySengkang area, but I have 2 routers, only one has been upgraded.![]()
No TP-Link ID, just log into the web UI like normal. Signed up and went live in June.To those who already received the update @JT2008 @Gforce_Ti @sean29 @derekli @kindredSG
Not sure they can "push" - my EB810v is in AP mode, so they can't talk directly (inbound) to it - the device would have to be phoning home itself to check for updates.Perhaps the FW rollout is pushed
SengkangHmm... possible cos that will tie to public IP address range. So @JT2008 @Gforce_Ti @sean29 @derekli @kindredSG @tcmean which area are you at?
In the network > internet > profile, do you have TR069 enabled in service type?Not sure they can "push" - my EB810v is in AP mode, so they can't talk directly (inbound) to it - the device would have to be phoning home itself to check for updates.
On its upgrade page it mentions ensuring the NTP settings are correct and enabled/working for it to do automatic updates, so that could be one thing to check.
It's in AP mode, it doesn't have that. TR069 is one of the reasons I moved it to AP mode - the port it uses is publicly accessible when in Router Mode, and I just do not trust Starhub or TP-Link to protect that port properly, so I moved it to AP Mode, which means there is no public IP associated with the unit now, so there can be no inbound connection to the TR069 port for management.In the network > internet > profile, do you have TR069 enabled in service type?
I just received the update this morning ..I feedback to support and requested for the firmware update.
I just got it now after I called them. But not the latest with speed test.I just received the update this morning ..
