Honor Magic V3
yhw22
I would like to ask you all. Do you unfold the phone as suggested to maximise charging speed when charging?
I will try to unfold while charging.
KeoNxaGa
I tried both and the remaining time to full is the same leh.
Perhaps it helps with heat dissipation?
tohchr
If u are in the Aircon environment, no need lar.. I never unfold before while charging.
tellim
Why my gpay qr code payment doesn't recognise qr codes outside when I tried to scan?
I already linked posb everyday cc and pay now receive ACC to my phone number.
How does the reward points work coz I still see $0 when I already started tapping to pay by credit card
tohchr
GPay scan does not support all the QR. Better use PayLah to scan if u have POSB/DBS. This is the Gpay issue..
Computeron
Y sometimes I unlock liao, there's is this magazine page.. How to remove ah? Every time I need to swipe off this pg. Like machiam I unlock 2x
I off liao leh in setting
Update..
A... This pg appears if I swipe up my lock screen from below. If swip from side won't come up
tohchr
Update..
U swipe from bottom. Swipe higher up will not trigger magazine unlock. I guess your finger pretty large. :LOL:
winningeleven
Just enable notifications for shopee app. I didn't do anything special. You can choose to enable/disable notification for different categories of messages.
I did the above but still unable to get the "shop pee" sound notification. Anyway doesn't matter also lah .
Kelvin0217
The v3 is a good phone, easy to hold on the hand as compared to Find N3. But the incoming call is a bit soft as compared to Find N3.
Any recommendations for case similar to the one that comes with the phone? Thanks.
