VIVIFI
testerjp
If I'm using iPhone 15. Can dual sim? Vivifi has esim?
Need to use for occasional overseas dual sim usage
Kepller
How is the customer support of Vivify compared to ZYM?
ZYM's customer support is lackluster in terms of responsiveness. Simple questions on their main live whatsapp chat can take up to 3-4hrs for reply per question. Is Vivify the same?
Megrez
Yes. I'm using Vivifi eSIM on iP15P.
Btw how's the data connection for you? I feel ever since they removed 5G trial, their 4G is a bit laggy, and signal strength is much weaker.
gapboy
  • 300GB Local Data (first 12 months);
    • 100GB thereafter
  • 300 Outgoing Local Minutes
  • 100 Outgoing Local SMS
  • 10GB Roaming Data to Malaysia (first 12 months)
    • 8GB thereafter
  • 1GB Roaming Data to Indonesia & Thailand (first 12 months)
  • Free Incoming Calls (on Singapore network)
  • Free Incoming SMS (Globally)
  • Free Caller ID
  • Free SIM Card or eSIM
Roam data limit to 12mth then downgrade
teoma
I had signed up for the Share plan a couple of months back where each sub line was $1/month for 12 months. It's less than 12 months but I want to add 2 more sub lines.
Currently, the promo for Share plan is $3.88/sub line for 12 months.
Any idea when I sign up for the 2 new sub lines, would I be paying:
1. Standard price of $6.50/line/month
2. Current promo price of $3.88/line/month
3. Previous promo price of $1.00/line/month
Asking CS but you know how long those could take, so seeing if anyone here got info. Thanks.
TitanSmall
signed the vivifi vibe 12 mths back.. now the free roaming gone.. any suggestions on where to go or which plan to switch to get (almost) the same price but with the free roaming to MY? best if the free roaming can be perm (1-2gb is fine)....
Tedicious
If U r ok with ST network, consider heya. Roll over data and roaming (up to 10 GB) every month. Use shopee coins to top up still got discount
hereiam7788
i am also on vivifi esim.. yes indeed after 5g free trial... left with 4G, sometimes i encountered blind spot also.. which means have data coverage but no data...
last time when i was with zym, their 5g stays forever even after the trial.... (it seems not a bug or what, but simply something quietly give to the users)
if not becos vivifi is the only mvno (not directly under sinktel) that has esim, i may stick to zym due to that...
Cumzilla
up to 10gb roaming only if u sign up the 5gb roam plan and rollover, if u get the 1gb roaming, only 2gb
Cumzilla
same here, my free roaming also disappear, tot is some bug or rather it happened just after I submitted the requested to switch to the vibe value plan...
rAcEr
Worth to port out of vivifi for existing customers then port in again later on to get benefits and discounts reserved for non singtel port in?
I'm currently paying close to 20 bucks for vibe 5g - don't think I have any free roaming after the initial 12 months period.
i.Singaporean
Haha different people have different view of "worth"
Go giga $18 5G for a month then jump back Vivifi $15 5G
gapboy
port to something else .. no freebies like roaming after 12mth is a deal breaker for almost everyone.. M1 maxx 7.90 plan is a good deal to port to as well
firesong
Deluxe Member
Port to $0 Eight plan. ;)
I think ZYM's $15 plan is a better deal than Vivifi's, especially since non-singtel port ins mean 5G is free. This would improve network coverage and performance for the user.
