Honor Magic V3
Kelvin0217
Oh, got one which both stand and Magsafe? Can link pls?
This is the one. With stand and magsafe is selling at rmb407 after discount.
【淘宝】限时官方立减69元 http://e.tb.cn/h.gsuhsJHQSehAJ9m?tk=RNLI38rnoFc CZ3460 「Benks适用荣耀magicv3凯芙拉手机壳中轴铰链磁吸保护壳新款极光超薄V3折叠屏典藏版凯夫拉碳纤维简约商务男士」
点击链接直接打开 或者 淘宝搜索直接打开
tellim
Battery life is better now. Can last me more than 12 hrs from 100% to 30% with WhatsApp surfing web, about .1.5hrs of gaming app w Bluetooth earbuds connection
terpeh
Sorry but do u apply WD40 on the screen before pasting the screen protector, or you apply on the screen protector after installing?
NeonX
Wha so good for you ah? Mine is probably 5 hrs sot at best
humyt
Just changed from iphone to Honor Magic V3 and realised GOMO eSIM does not support this phone.
Anyone knows which SIM only plan supports this phone in eSIM?
stealthviper79
Hi guys, I have been struggling to identify a solution for mounting this phone in the car, with wireless charging. Does anyone have a solution ?
kashix
Are you sure????? Why my friend can use??????
LOL!
NeonX
Magsafe solutions? I'm attaching via magsafe, easy and convenient. If case no magsafe then go stock a metal ring, which is what I did on my original case
Xue
My wife actually got iPhone 16 Pro, played with the phone for 2 days before letting her use it, and I feel it's almost same as iPhone 15 Pro. Camera button is hard to use and not very Apple-like. So now back to V3 and it feels nicer, although some stuff can be janky (like going back gestures feels less smooth and no Face ID for bank apps)
rchow2008
Not sure about the effectiveness of the RainX which is mainly used to disperse water droplets so that it glides smoothly on the windshield of the car. But this silicon based lubricant seems to repel grime and dust more effectively when I first experimented a year ago. I have been using it for almost every tempered glass protector except for my last Z Fold when I used Samsung's anti reflective screen protector which have very minimal fingerprint smudges and the surface is very smooth to glide as well. I wished that anti-reflective screen material can be used on all phones in the future.
Of course, using this silicon lubricant method will still have some fingerprint smudges albeit it is lesser now and also easier to wipe away with a micro fibre cloth. YMMV. No harm trying if you have some of this lubricant in your home.
Thanks, will try WD40 instead when I get a TG SP. RainX makes it easier to clean, but still get prints.
Imak TG SP users, how is it? Still good with front case?
tohchr
I preferred fingerprint, need not lift the phone up and smile stupidity at it. This V3 I just use my thumb can liao
Ray1976
I considered lucky as I am able to fit the outer case snuggly with the TG put on. I know some bros here have a ill fit. Guess there is some minor deviation from the fit for different batches.
