⚡️💻 [Official] README First! 2026 SG ISP Comparison & Latest Promo Deals! ✨
Bennychow722
When the ISP provides an ONR (that isn’t bridged) the R means routing. The ONR handles the routing. Some “geeks” (like me, as it happens) prefer to use our own routers so that we have more control over how the network is managed on the home side (and potentially better security), but for most typical home users it doesn’t matter. You should be able to go into the ONR’s settings pages and configure/reconfigure basic routing functions if you ever need to. (Unlikely.)
Since the ONR is handling the routing functions you don’t need another router. If you want Wi-Fi you only need at least one wireless access point (WAP). Or a wireless router that’s configured as a WAP (i.e. you shut off the routing functions in the wireless router). If you configure routing functions (in addition to what the ONR already provides) then you get what’s called “double Network Address Translation” (double NAT). Usually that’s tolerable, but a double NAT configuration can negatively affect some applications.
I suppose the advantage of an unbridged ONR is that you can choose all WAPs for your home (not only a wireless router that you configure as a WAP), and there are some very good WAPs at reasonable prices. There seem to be a lot of crappy wireless routers but fewer crappy WAPs in the market.
WOW!!! Thanks for your explanation. If i sign up a ONR plan and use the free router provided by ISP(put in my DB box), i could just buy a WAP and set up at my common room to extend the wifi right?
Thanks for your time and explanation.
BBCWatcher
Yes, that's correct. The "free" (you always pay for it, of course — "bundled" is maybe a better word here) wireless router the ISP provides, if it provides one, would be configured as a wireless access point (routing functions shut off) if the ISP is also providing an unbridged ONR. [Sometimes the ISP provides a combined unit (ONR plus wireless access point in one physical box).] Then you could add a second or even third wireless access point if you'd like. The second "far" WAP has to be connected to the ONR somehow, preferably through a wired connection.
If you want the two WAPs to coordinate with each other then it's probably best if they're provided by the same vendor. For example, if the ISP provides a wireless router (used as a WAP) from ASUS then a second WAP from ASUS may offer some advantages. Specifically, there are protocol standards for wireless roaming: 802.11r/k/v. But there doesn't seem to be good cross-vendor support for these protocols, or at least that hasn't been my experience so far. These wireless roaming protocols allow two or more WAPs (or even one WAP with its 2 or more radios) to help more quickly steer wireless clients to the "best" radio as the clients move around, if they move around. There are a lot of debates about whether wireless roaming offers much benefit. I have it set up, and I think it's a modest improvement that I occasionally notice if I'm on a voice call (such as FaceTime, Zoom, etc.) and move around. With wireless roaming working properly the device can jump more quickly from WAP to WAP (or even from the 5 GHz radio to the 2.4 GHz radio on the same WAP if that's a better jump), and you're less likely to hear a break in the audio. But "less likely" doesn't mean "impossible." These protocols only provide a little guidance to wireless devices, but it's still up to the devices to make good decisions. YMMV.
So how do you get a second WAP connected to the unbridged ONR? Here are some options:
  • Run an Ethernet cable (across the ceiling, for example). That's nice and stable, but it can also be pretty ugly and/or involve some installation costs. Some people run fibre cables across their homes just in case they want super fast wired connections. (Copper cables can go pretty fast, but they trail behind fibre.)
  • If you happen to have "legacy" coax cable or even telephone cable inside your walls, use that. Get a pair of adapters (currently MoCA 2.5 or G.hn Wave 2 for coax, or G.hn Wave 2 for telephone cable) that bridge Ethernet onto that in-wall cabling. I'm using MoCA over coax, and it works really well. It's super stable, and the performance is very good — up to around 2.0+ Gb/s with the latest MoCA adapters equipped with 2.5 GbE Ethernet ports, or still very reasonable ~0.9 Gb/s with 1000BASE-T ports. It's a good idea to turn on encryption in these adapters just in case you're "broadcasting" to some neighbor that's also connected to that coax or telephone cable loop. You're not limited to 2 adapters if you have multiple rooms with coax or telephone cable ports on the same loop. You can bridge between 3 or even more adapters.
  • Use Powerline adapters to do the same thing. Powerline adapters bridge over your home's electrical wiring. They're typically slower and less reliable than coax or telephone wiring. TP-Link sells many of these adapters. Sometimes you can buy a Powerline adapter that includes a built-in WAP (a single combined unit).
  • Use a wireless backhaul, meaning the "far" WAP communicates wirelessly with the WAP (or wireless router configured as a WAP) located near the ONR. It's better if this wireless communication is over a dedicated channel using dedicated radios since that offers better performance. But it's also possible (although slower) to share radios/channels with wireless devices. Naturally the WAPs and wireless routers with dedicated wireless backhaul radios cost more.
  • Use some combination. For example, if you're using Powerline bridging you might pair that with wireless bridging. If you have the equipment to do it.
Bennychow722
Thanks for your clear explanation. Let me digest it haha
Just some history here.
https://www.tech.gov.sg/media/technews/history-of-the-internet/
Fibre internet service
1) 2010: 25Mbps/50Mbps/100Mbps/1Gbps plans, M1 1Gbps is at S$399 per month.
https://www.hardwarezone.com.sg/tec...ces-new-broadband-plans-new-national-fibre-ne
https://corporate.starhub.com/about...omebroadbandplansfornextgenerationnation.html
2) 2013-->2014, rapid price drop of 1Gbps services. I actually did not know that Singtel was a late comer to 1Gbps plan. MR was the disrupter then.
https://www.hardwarezone.com.sg/feature-overview-fastest-fiber-broadband-plans-singapore
3) 2016 --> 10Gbps plan launched by SIngtel/M1/VQ/SI with much lower price than when 1Gbps plans were launched in 2010. It was probably ahead of its time so only Singtel kept the 10Gbps plan until Starhub launched 10Gbps in 2023.
10Gbps plan Launch price --> Singtel/M1 at S$189 per month, SI at S$199 per month, VQ 10Gbps plan at S$218 per month.
https://www.hardwarezone.com.sg/tec...ngtels-crazy-fast-10gbps-fiber-broadband-plan
https://www.hardwarezone.com.sg/tech-news-now-you-can-sign-m1s-10gbps-fiber-broadband-plan-your-home
https://www.hardwarezone.com.sg/fea...s-end-end-10gbps-home-fiber-broadband-service
4) 2023/2024 --> rapid drop of 10Gbps plan pricing.
It is good to have the price war.
Let's see if Stathub/MR and Singtel will reduce the price of 5Gbps/10Gbps plans.
Let's see if M1 will provide new competitive 5Gbps/10Gbps plan as well.
1. No-frills 5Gbps/10Gbps plan: #4 and #5 with ONT can be considered as no-frills plan as the user will need to get their own router.
1) VQ 10Gbps: effective price is at S$38.75 per month.
CGNAT but with static IPv4 add-on at S$4.03 per month. Using bridged ONR (same as ONT) by default, but allow the user to request to change to router mode (normal ONR).
2) WC 10Gbps plan at S$29.99 per month, using ONR, with public IPv4 address.
3) SIMBA 10Gbps plan at S$29.90 per 30 days. CGNAT. With public (routable) IPv6 address but no public IPv4 address
4) Starhub 5Gbps plan with Nokia all-in-one ONR (AX6000 WiFi 6), with public IPv4 and IPv6, at S$45 per month. It is reported that the use can request to change to ONT. But there is a special offer of Starhub 5Gbps plan (mainly for new users) at S$29.55 per month (with the Nokia ONR and an extra Nokia Beacon 2 as mesh node).
5) Starhub 10Gbps plan with Nokia all-in-one ONR (AX6000 WiFi 6), with public IPv4 and IPv6, at S$59.05 per month.
It is reported that the user can request to change to ONT. Bundled with 24 months EPL.
2. 5Gbps/10Gbps Plans with 10Gbps capable WiFi 7 router
1) VQ 10Gbps With 10G capable WiFi 7 router (eero Max 7) the effective price is at S$53.75.
2) Starhub 5Gbps plan with ONT + EB810v WiFi 7 router at S$55.09 per month.
3) Starhub 10Gbps plan with ONT + EB810v WiFi 7 router at S$69.95 per month. Bundled with 24 months EPL.
4) MR is using CGNAT but static IPv4 is at only one time charge of S$51.
MR 10Gbps plan with ONT + TP-Link Archer 805 at S$59.99 per month plus S$50 one time top-up (first three month also got S$10 rebate).
MR 10Gbps plan with ONT + eero Max 7 at S$62.99 per month plus S$50 one time top-up (first three month also got S$10 rebate).
MR 10Gbps plan with ONT + 2 x TP-Link Archer 805 mesh at S$69.99 per month plus S$50 one time top-up (first three month also got S$10 rebate).
5) MR 10Gbps Gamer plan with ONT + TP-Link Archer 805 at S$64.99 per month plus S$50 one time top-up (first three month also got S$10 rebate).
MR 10Gbps Gamer plan with ONT + Asus ROG GT-BE250000 flagship WiFi 7 router at S$74.99 per month plus S$150 one time top-up (first three month also got S$10 rebate).
6) Singtel 5Gbps plan with ONR plus HB810 WiFi 7 router at S$59.90 per month; With public IPv4 address.
7) Singtel 10Gbps plan with ONR plus HB810 WiFi 7 router at S$79 per month
Singtel 10Gbps plan with ONR plus 2 x HB810 WiFi 7 mesh at S$89.80 per month
8) WC 10Gbps plan with ONR plus HB810 WiFi 7 router at S$58.90 per month.
jess_sy
Singtel drop price for 10Gbps
10Gbps Enhanced (WiFi 7) at $69/mth (U.P $139/mth)
  • [ONLINE EXCLUSIVE] Comes with FREE Nespresso Vertuo Pop (worth $249)
  • Comes with XGS-PON Optical Network Router + 1 unit TP-Link BE22000 WiFi 7 Router
10Gbps Enhanced Mesh (WiFi 7) at $79.80/mth (U.P $172.60/mth)
  • Comes with 2 units of TP-Link BE22000 WiFi 7 Router
Nice one.
https://www.singtel.com/personal/products-services/broadband/eform/10gbps
All-in 10Gbps plan​
(U.P $139/mth, 24-mth contract)
[ONLINE EXCLUSIVE]
  • Get a FREE Nespresso Vertuo Pop Coffee Machine (worth $249) with any 10Gbps broadband plan sign-up
*Not applicable to 10Gbps WiFi 6 Mesh Plan with lifestyle gadget at $79/mth
Our all-in Fibre plan includes:
  • Home Line
  • Mobile Broadband (500MB)
  • Weekday / Weekend router installation waiver worth up to $147.71 (Online Exclusive)
  • Registration Waiver worth $54.50
  • NLT SAC Waiver worth $61.04
  • 12 mths of Disney+ Premium on us (U.P $15.98/mth applies thereafter)
  • 12 FREE months of All-new Singtel TV (new TV sign-ups only)
  • 12 FREE months of Broadband Protect (U.P $3/mth applies thereafter)
  • 12 FREE months of Amazon Prime (U.P $2.99/mth applies thereafter)
  • 12 FREE months of Viu Premium (U.P $7.98/mth applies thereafter)
  • 12 FREE months of McAfee Security Suite Plus (U.P $10.08/mth applies thereafter)
  • 6 FREE months Sport Plus (U.P $20.28/mth applies thereafter)
10Gbps Enhanced Mesh Plan WiFi 7 at $79.80/mth (U.P $172.60/mth)
  • Comes with XGS-PON Optical Network Router + 2 units of TP-Link BE220000 WiFi 7 Router
10Gbps Enhanced Plan with WiFi 7 Router at $69/mth (U.P. $139/mth)
Singtel also slightly drops the price of 5Gbps plan, but not much.
5Gbps with HB810 router --> was at S$59.90 per month, now at S$57.90 per month.
Take note I do not recommend the other two options with lousy Singtel Mesh solutions.
https://www.singtel.com/personal/products-services/broadband/eform/5gbps
5Gbps Enhanced Mesh Plan WiFi 6 at $57.09/mth (U.P. $106.09/mth)
  • [ONLINE EXCLUSIVE] Comes with FREE Mayer 5L Digital Air Fryer (worth $349)
  • Comes with 1 unit of Singtel WiFi 6 Router and 1 unit of Singtel WiFi 6 Mesh
5Gbps Enhanced Mesh Plan WiFi 6 at $60.18/mth (U.P $116.28/mth)
  • Comes with 1 unit of Singtel WiFi 6 Router and a pair of Singtel WiFi 6 Mesh Extenders
5Gbps Enhanced Plan with WiFi 7 Router at $57.90/mth (U.P. $95.90/mth)
aikhamarc
You can probably consider TP-Link Deco XE75 Pro three-pack at about S$729.
Main router in the ONT area, the other two nodes in Bedroom 3 and Main Bedroom, as you planned. But you can also try to play with the placement to optimize the performance.
M1 used to have good bundle price for TP-Link Deco XE75 Pro. You may want to check with them.
I went to try, the lan port in bedroom 2 is working. Will there be other options available?
In that case, you can probably use a cheaper dual band mesh solution with Ethernet backaul. Main router in the ONT area and mesh node in the Bedroom 2.
What is your budget?
ONT vs ONR topics are kind of beaten to death already.
CGNAT (VQ/MR/SIMBA) is less talked about.
Majority of users will be okay with CGNAT but some users get affected (eg: cannot do port forwarding).
VQ/MR provide static IPv4 add-on for those who hit the limit of CGNAT.
Unfortunately SIMBA does not have that add-on. It provides public IPv6 for 10Gbps plan users as a potential work-around but not able to sort out all issues.
https://en.wikipedia.org/wiki/Carrier-grade_NAT
  • Carrier-grade NAT usually prevents the ISP customers from using port forwarding, because the network address translation (NAT) is usually implemented by mapping ports of the NAT devices in the network to other ports in the external interface. This is done so the router will be able to map the responses to the correct device; in carrier-grade NAT networks, even though the router at the consumer end might be configured for port forwarding, the "master router" of the ISP, which runs the CGN, will block this port forwarding because the actual port would not be the port configured by the consumer.[7] In order to overcome the former disadvantage, the Port Control Protocol (PCP) has been standardized in the RFC 6887.
  • In cases of banning traffic based on IP addresses, a system might block the traffic of a spamming user by banning the user's IP address. If that user happens to be behind carrier-grade NAT, other users sharing the same public address with the spammer will be inadvertently blocked.[7] This can create problems for forum and wiki administrators attempting to address disruptive actions of a single malicious user sharing an IP address with legitimate users.
aikhamarc
Previously you advised that I can get a AX72 on top of the bundled BE230. Does this combination still work?
XB
Where to find this? Thanks ** got it from their website**
Starhub 10Gbps plan with Nokia all-in-one ONR (AX6000 WiFi 6), with public IPv4 and IPv6, at S$59.05 per month. It is reported that the user can request to change to ONT. Bundled with 24 months EPL.
orangbulu
Hi @xiaofan If I am changing from 1gbps to 2.5gbps or 10gpbs internet, does the network termination point need to be rewired/ replaced?
Currently renovating my house and I want to put the existing TP in my cabinet. So wanted to know whether I need to replace my TP first before carpentry work starts.
It is here.
https://www.starhub.com/personal/broadband/10gbps.html
If you do not have 10G capable router, I will actually recommend the more expensive option with EB810 at S$69.95 which comes with ONT by default.
For the Nokia ONR option, if you want to change to ONT, you need to have your own 10G capable router to enjoy 10Gbps. And it it is said that you need to go to physical shop to make it black and white to give you the ONT. If not, after the installation of ONR, it becomes more difficult to get the ONT.
No. Usually each household has two Fibre Termination Points. So your new ISP will use the remaining one. NLT will need to activate the second port before the new ISP can install their Fibre Internet service for you. After that you can deactivate the first ISP's service.
Latest BTO flat has four Fibre Termination Points.
It seems to me that people are having issues to get the complete list of Starhub Fibre Internet plans.
https://www.starhub.com/personal/st...nd-wifi-6---mx2_2000mbps-fibre-broadband.html (2Gbps)
https://www.starhub.com/personal/broadband/5gbps.html (5Gbps)
https://www.starhub.com/personal/broadband/10gbps.html (10Gbps)
https://www.starhub.com/personal/st...speed-5gbps-onr-at-2955_ultraspeed-5gbps.html (Speical offer 5Gbps plan at S$29.55 per month, ONR option only, no change to ONT).
Starhub does not offer standalone 1Gbps service to new customers but only Homehub+ 1Gbps.
https://www.starhub.com/personal/store/homehub/browse/products/new-homehub_-1g.html
There are different types of Homehub+ bundle, with 10Gbps plans.
https://www.starhub.com/personal/store/broadband.html
Example: UltraSports HomeHub+ UltraSpeed 10Gbps Bundle (24-month)
https://www.starhub.com/personal/st...--_ultrasports-homehub-ultraspeed-10gbps.html
Example: HomeHub+ UltraSpeed (Asian+) WiFi 7
https://www.starhub.com/personal/st...ducts/wifi-7--_asian_-homehub-ultraspeed.html
Starhub 5Gbps plans: if you do not need EPL or the Homehub+ contents, then Starhub 5Gbps plans are more worth than the 10Gbps plans.
1. Normal Starhub 5Gbps plan:
2. Special 5Gbps offer with Nokia ONR (can not change to ONT) and one Nokia Beacon 2 to form a mesh
3. Special 5Gbps offer with ONT -- nobody has been able to get this offer installed with ONT so far (a few are trying). Not so sure if the link will be valid for long.
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html
