Google Pixel Buds Pro 2
limmk
TL;DR
  • The Google Pixel Buds Pro 2 case can wirelessly charge at up to 5W.
  • That’s double the wireless charging speed of the original Pixel Buds Pro.
  • This change is documented in the Qi certification filing that Google made with the Wireless Power Consortium.
The Google Pixel Buds Pro 2 can wirelessly charge much faster than the original​
Google has doubled the wireless charging speed of the Pixel Buds Pro 2 case.
Although the Made by Google event wrapped up yesterday, we’re still learning more details about the new Pixel devices that Google unveiled. For example, we just found out that the Google Pixel Buds Pro 2 can wirelessly charge much more quickly than the original Buds Pro.
The new Pixel Buds Pro 2, on paper, seem like they’ll be a contender for the best wireless earbuds you can pair to your Android device. They’re small, lightweight, have great noise cancelation, and supposed long-lasting battery life. According to Google, they can deliver up to eight hours of playback with ANC turned on. Once the earbuds run out of juice, you can plop them back in the case to quickly recharge them. The case can fully recharge the earbuds almost three times over, delivering up to 30 hours of total listening time with ANC enabled.
When the battery in the Pixel Buds Pro 2 case is fully depleted, you can recharge it using any USB-C wired charger or Qi wireless charging stand. Google’s product page doesn’t mention how fast the case can be recharged, but thanks to the Wireless Power Consortium — the standards body responsible for Qi wireless charging — we know that the Pixel Buds Pro 2 case charges wirelessly at a maximum of 5W. That’s double what the case of the original Pixel Buds Pro can handle, at least according to Google’s WPC certification filing for that product.
WPC filing for Pixel Buds Pro
WPC filing for the original Pixel Buds Pro
WPC filing for Pixel Buds Pro 2
WPC filing for the Pixel Buds Pro 2
Without knowing the capacity of the battery in the Pixel Buds Pro 2 case, we can’t estimate exactly how long it’ll take to fully recharge it using a 5W or higher Qi wireless charger. The earbuds won’t be released until late next month, so we won’t even be able to test this ourselves for a couple of weeks. I’m personally curious how long it’ll take to wirelessly recharge the case using the Battery Share feature on the new Google Pixel 9 series. Regardless, the fact that Google not only made the Pixel Buds Pro 2 last longer but also charge faster is great, as it means there’ll be even less downtime without your earbuds.
You can pre-order the Pixel Buds Pro 2 now for $229 in the US, £219 in the UK, and €249 in Europe in Porcelain, Hazel, Wintergreen, or Peony colorways. Click the button below to get started.
meet_nanda
Lai liao...
Early impression... better anc, better sound.
Case feel solid, got built in speaker.
Thanks for the early impressions. Couple of questions:
1. Are the buds considerably smaller than previous one?
2. Does the wing tip help with secured fit?
garychengjw
nice first impression. i'm holding my moola for this, am still using og pro.
waiting price drop 1st :s13:
omelet
1. Body is slightly smaller, felt like the Pro just lost weight and became slimmer. Case is the same size, but have extra holes beside the charging port for the speaker.
2. Not really sure, the OG pro already stays in my ears. I gotta use this outside tomorrow to tell if it is better.
meet_nanda
Looks great! Thanks for the pictures.
halocast
The mics seems bad ?
Not sure if firmware updates will improve it. :o
limmk
Introduced last year for Chromebooks, the Pixel Buds web app now supports Mac and Windows.
mypixelbuds.google.com works on macOS 14 Sonoma or newer and Windows 11 or newer after previously being limited to ChromeOS 127+. (It was version 117 a year ago.)
Pixel Buds Mac Windows
Once your Pixel Buds are paired to the computer, visit that website and select it. You can save “Pixel Buds” as a Progressive Web App (PWA).
Afterwards, you see the battery status of the case and each bud. With Pixel Buds Pro, you can set:
  • Active Noise Control: Off, Noise Cancellation, and Transparency
  • Conversation Detection
  • Multipoint
  • Touch controls
  • Equalizer
The “More Settings” gear icon at the top lets you access:
  • Mono Audio
  • Volume EQ
  • Volume Balance
  • In-Ear Detection
  • Device Serial Numbers
Finally, there’s a Firmware section to update your Google headphones without an Android device. The expansion beyond Chromebooks to Mac and Windows should just about make Pixel Buds available to all that are interested.
garychengjw
Gotten my buds and initial impression... It's really improve alot from last gen and sounds good.
Now it's fit nicely and wouldn't drop so easily like OG Pro.
