Does this starhub 5Gbps plan uses bridge ONR or ONT ?
1. Nokia XS-2426X-A ONR with wireless AX6000, not bridged. And not able to change to ONT.
And it cannot be bridged unless you catch the one time super-admin password during the installation. Take note Starhub SOP for the installater says not to give the super-admin password to the user.
This is actually the cheapest way to get the user to jump to 5Gbps or 10Gbps as Nokia XS-2426X-A is kind the cheapest 10G capable wireless router (AX6000 WiFi 6). I understand power users usually do not like ONR, but many user may not care and just care about low cost.
2. Comparison of SIMBA 10Gbps plan, WC 10Gbps plan and Starhub 5Gbps special offer
Power users do not like ONR. But ONR provides cheap setup to achieve 10Gbps.
And at least WC 10Gbps and Starhub 5Gbps plan will be more stable than SIMBA 10Gbps as of now.
For power users, better go with VQ 10Gbps (ONT) and Starhub 5Gbps/10Gbps plan with ONT + EB810v option.
For average users, Starhub 5Gbps special offer has the best value now.
1) SIMBA 10Gbps --> S$29.99 per 30 days, using CGNAT (no public IPv4 address).
The user needs to get his own wireless router. 10G capable wireless router is not cheap. If the user opts to use 2.5G capable main wireless router, the plan becomes 2.5Gbps. If the user opts to use 1G capable main wireless router, the plan becomes 1Gbps.
2) WC 10Gbps --> S$29.99 per month, 10G capable ONR provided, not using CGNAT (with public IPv4 address).
The ONR is the main router for the home network. The user needs to get his own wireless router. 10G capable wireless router is not cheap. But the user can reuse his own 1G or 2.5G wireless router. It is still possble to use one 10G wired device since the ONR has one 10G LAN port. WC alsp provides another option with HB810 bundle but that is totally not worth it at S$58.90 per month.
https://whizcomms.com.sg/10gbps-broadband/
3) Starhub 5Gbps special offer with Nokia XS-2426X-A all-in-one ONR --> S$29.55 per month. Not using CGNAT, with public IPv4. IPv6 is also supported.
The user does not need to buy his own router to enjoy 10Gbps. And it includes one Nokia Beacon 2 which can be used as a mesh node (1Gbps capable only mesh node). It is also cheap to get second Nokia Beacon if more mesh nodes are needed.
I am not saying the Nokia Beacon 2 or even the Nokia XS-2426X-A is good, it is just that this is the cheapest way to get the user started.
Starhub has fixed its backend congestion issue and now publish typical speed for 5Gbps and 10Gbps plan.
https://www.starhub.com/personal/broadband/typical-broadband-speed-plans.html
| Typical Download Speeds | Local |
| 1Gbps | 970 Mbps – 975 Mbps |
| 5Gbps | 4116 Mbps - 4783 Mbps |
| 10Gbps | 7599 Mbps – 8231 Mbps |
