Starhub Giga
ontodhcp
got free monthly 4gb roaming data for the $12 plan. go app to upgrade for free.
But there's a catch, even though the data, talktime, sms remains the same, it's still consider a change of plan when you upgrade, so any existing data rollover will be reset on your next cycle.
HWZ1973
I'm currently on $10 plan, saw a free upgrade offer but no details of the upgrade, can anyone advise?
sibeiTrolled
A7997A
1 selection so difficult ah?
Depending on your phone and situation, just waiting for the list of networks to show up could take few minutes.
Selecting the network itself is the easy part.
Also when you move out of coverage of 1 network, you need to manually select the other network.
In the best case scenario 1 of the networks will cover you fully.
In the worst case scenario you need to switch network manually regularly, each time few minutes, that can drive you crazy.
