overratedplot
- May 3, 2024
Bittorrent should work fine with IPv6 without doing anything. For Plex and WireGuard, IPv6 access will not really be any different except "more digits". It's just that you will only be able to access them if you connect from an IPv6 network, so it depends a bit on where you normally access them from.I need to do port forwarding for Plex hosting, Qbittorrent and WireGuard.
What are my alternative options? Totally not familiar with IPv6 other than it has more digits haha.
If you want / need IPv4 than your options are using something like Cloudflare Tunnel, Tailscale, or another tunnel/VPN that allows remote connections (basically routed through a third party).
