upgrading my gpu
deepblue_82
going to buy a rx5700xt this weekend Sapphire Pulse Radeon RX 5700 XT
but i read that its a 2.3 slot size card
this is my current rx 570
i read on the internet its a dual slot card
guys please help would u know if it would fit?
naked123
RX 6600 XT is shorter (mostly) and faster
*most 5700 XT is longer
y2c_whtdouwant
You still have 4 empty PCI covers, yes it will fit.
Unless the card is too long for your case.
deepblue_82
Ah, the connectors look quite tight in your current situation.
Getting a thicker one is not advisable:s22:
how to do think i can fix this? change connectors or change mb?
the incoming card to a Sapphire Pulse Radeon RX 5700 XT
its a 2 fan model so the length should not be a problem...
its about the thickness...
y2c_whtdouwant
Easy way, change mb to an atx one. But it will cost you more.
Hard way, find a way to connect those mb headers with the thicker card:s22:
deepblue_82
jk la.. i am not changing my mb
my current rx 570
do u think possible or i am just dreaming?
y2c_whtdouwant
my current rx 570
I'd say not possible. Front panel connectors should be fine given the space between the card and mb.
It's the other connector which I'm worried about. Either do away with that connector or find a right angle one and hope there's enough space:s22:
deepblue_82
sorry ah i am not that pro to know which connector u are talking about...
do u mean the front of the card the black connector or the colorful connector?
deepblue_82
looks to be a tpm connector
soreloser
looks like most b450m/b550m boards have very little space between the pcie slot and the connecting wires. Think there is not much you can do about that. If you take a look at the layout of a b650m board, there's a lot more space for a larger gpu now. Maybe have to go for a smaller gpu like a twin fan 6600xt? or a 4060 slim of some sort.
deepblue_82
got it fixed up....... in the end the size was able to fit in.
the thickness was ok.
just that the length the end of it was blocking a stata port...
removed it, it was for my cdrom...
now all good...
thanks for all the replies
deepblue_82
while running pupg on max settings on 1080p my fps was already 61 fps via 570 8gb
now running rx 5700xt the fps came down a bit to 58.9 fps...
i used ddu and followed the order...
now installed latest amd drivers...
same max settings.. at 1080p
anyone can give me some tips?
cs2 at 200 fps max settings
soreloser
CS2 got improved fps or stay the same? And what CPU and RAM are you using
