cpuer
- Jan 8, 2003
next week then stat using in JP.hi, how was review on your esim?
I used 3gb/day e-sim from this hk-based company. Paid in USD using youtrip card. They have an unlimited plan as well.Are there any e-sim which offer unlimited or high data daily usage?
As I will be driving and will also be streaming music (Spotify) in the car, this will require high data usage.
My recent airalo expeience was positive, posiive in connectivity, didnt bother with speed tests, whatsapp, instagram, yt, google maps, X, etc. Been to ulu ulu places in Gifu and Toyama pref. Things that I normally do in singapore they worked there too. Most of the time I was on their Softbank network.Any recent review on airalo or ubigi? Was considering this 2 or just go for singtel roaming haha
not sure if airalo has activated 5G by now but I used ubigi for my last trip because it has 5G.Thanks alot! Guess I will stick with airalo or ubigi
probably have to buy when you touch down there at the physical shops.Any recommendations for a non-esim card that can make calls for Hokkaido?
rakuten mobile tooAnyone has any experience with the roaming provided by Simba in Japan? Coverage and speed? Is it solely KDDI?
That’s about 1GB/day, are you doing only navigation?Just bought ICC SIM card 10 Gigs for 10days... not sure good or not... will know only when try there in Tokyo.
Can i know why google.maps use so much data? U using it for navigation?That’s about 1GB/day, are you doing only navigation?
I’m in Tokyo, it’s my 3rd day now and using about 2GB/day using IG, YouTube, and Google Maps
when i roaming with low data mode, my usage is less than 500MB per day. I only use data for maps, X, IG, WA and some google search. If intensive map use is expected, it's better to dowload off line maps first before setting out.Can i know why google.maps use so much data? U using it for navigation?
Ive always used unlimited data in japan. But this time i wanna use the free roaming data in my sim plan, mainly for google maps. So I'm surprised to see the high usage.when i roaming with low data mode, my usage is less than 500MB per day. I only use data for maps, X, IG, WA and some google search. If intensive map use is expected, it's better to dowload off line maps first before setting out.
