Honor Magic V3
DeepseaG1523
I have updated to software v 155. Previously I created the shortcut for the face to face translation apps. But recently it's gone. I tried to add it back and it says the shortcut is added. However, I can't find it on the phone. I do a search on phone also can't find. What can I do?
the latest software is 175 not 155, try press the tryout version to get 175.
as for the shortcut, did u change ur home screen style from drawer to standard? if yes, change back and the shortcut will appear.
Hardware78
Thanks for the enlightenment! Does it mean I can only see the f2f translation apps only in standard mode? In drawer mode, I can't use it as I can't find it.
DeepseaG1523
yes, if u wan change to drawer mode, delete the shortcut first on standard mode first den when u switch to drawer mode den u go add the shortcut again.
V_for_Vanilla
Sorry to off topic. Anyone has any thoughts on Xiaomi's mix fold 4? I don't see it on Xiaomi's official store.
Hardware78
Anyone knows how to install Douyin apk on this v3? It said the phone is not compatible. Do I need to disable something before it can install apk?
tohchr
Open google play store, click on your profile on top right, select play protect and then turn it off. After installing completed, turn it back on.
tohchr
Still can’t install after I turned it off. It still says “ App not installed as app isn’t compatible with your phone.”
Oh, u might have downloaded a wrong version. I had 抖音 installed as well..
glorygoh
The longer way is settings>assistant>yoyo assistant>f2f translation.
KeoNxaGa
Have douyin installed no issue. It prompted to allow installation of apps from non playstore that I have to agree. Maybe you guys need to do that?
