Vivo X200 Series
final1
Anyone know if the china rom itself can install Google things and use GMS? Currently in china quite tempted to buy one
sometimes may have some problems with some apps if using china set with china rom.
But, hard to predict.
If not keen to troubleshoot stuff, better to avoid.
speedknight
Moderator
Moderator
Things theat wont be working with CN rom:
Android auto (But might change too)
Your CN rom will only work with CN Wear OS watches,
if you need to install 2 WearOS APK/app CN and global for WearOS global devices.
PIXEL watch wont work because it Require Pixel watch app and there isn't pixel watch CN app
mukushu
No such issues. OriginOS has a settings to enable Google Services. I used S18Pro, X100 Pro before. Only thing is you need to download Google Play Store apk yourself. In fact OriginOS 5 is much advanced than FuntouchOS.
If you are in China, phone available for sale on Friday only. I preordered last week a Titanium 16GB+1TB in Chengdu, collecting on Thursday evening.
vibranze
X200 mini is as good as X200 Pro, the telephoto aperture is bigger than the pro version despite the smaller sensor and shorter focal length, the other downside is there is no 3D LUT import in mini, not sure why they take out this feature 😔
ShinnAsuka
1982-1994
Surprised the mini doesn't support USB 3
transferring of files will be painful
Alexz_Hong
still got a few other differences. as someone mentioned, USB 2.0 port on Pro Mini, only X200 Pro gets USB 3.2 (with DP support). a few other difference i noticed on their specs page, screen on mini is 1-120Hz compared to 0.1-120Hz on the Pro, the resolution for video is a bit lower at up to 4k for regular video, 1080p for slow motion on the mini, 8K and 4k for slow motion on the pro, fingerprint sensor is optical fingerprint sensor on mini, ultrasonic on the pro, pro has something listed called "多光谱传感器" (multispectral sensor) which isn't listed on the mini. but otherwise, it's probably the most feature packed android phone we've seen so far? most of them probably aren't a huge deal, but USB 2.0 with seemingly no display out is a bit disappointing for a phone this price. if got DP support like iPhone 15/16 at least a bit easier to swallow...
kuma-mon
the camera specs are also different
x200 pro uses a new telephoto lens
x200 pro mini:
50MP Sony IMX882 1/1.95″ sensor, f/2.57 aperture, telemacro, 3x optical zoom, OIS
x200 pro:
200MP Samsung HP9 Zeiss APO 1/1.4″ sensor, f/2.67 aperture, telemacro, 3.7x optical zoom, OIS
source:
https://www.fonearena.com/blog/437974/vivo-x200-pro-price-specifications-x200-pro-mini-x200.html
frizee
Any thoughts on Vee Gadget?
I see X200 Pro 16/512 version all in $1178 :)
mukushu
Just collected a while ago. Smooth AF 😊
