- Jul 5, 2001
Where u collect?![]()
Just collected a while ago. Smooth AF![]()
Chengdu, Jin-niu, CapitaMall.Where u collect?
Just buy from shopee, they import from chinaAnyone order from China directly?
Which seller did you order from?Just buy from shopee, they import from china
https://www.bilibili.com/video/BV1sVyYYJE5a/ this?Apparently lens flare (idk if it's the correct translation) is more prevalent on main camera of X200 series.
Don't know if its just few devices or a wide spread issue.
Search "vivo X200ē³»åāē©å āäø„é" on bilibili (Can't post link due to new account)
thats finehttps://www.bilibili.com/video/BV1sVyYYJE5a/ this?
oof... i've seen this on some phones before when a bright light source hits the lens at an angle, but it does seem more obvious on the X200 series. probably have to avoid certain types of lighting or tilt the phone to adjust a bit so the light hits a bit differently on the lens?
wow, they're damn pro at the tests, respectmediastorm's explainer about the "light flare" thing.
https://www.bilibili.com/video/BV1jw1wYJEAw
