Google Pixel 9 Pro Fold
DigDub
Anybody tried the itskins case? Went around causeway point today and they only have this case for this phone.
Can try sim lim square 4th floor orient electronics. Whole shop selling phone cases. Got a transparent one from there.
DigDub
Yes this is the one I did at the tech house in Westgate too. They have a real glass cut out but for the privacy matte, it felt more like a screen protector though it's supposed to offer protection too
Hmm... Maybe they run out of the privacy glass one liao.
ForumRider
the transparent one they sell no adhesive.. front case easily come off
I bought mous, its a joke, the adhesive is very bad and it made my screen protector come out. The line on the left side of the main screen also bent that I have to adjusting it and the adhesive is not sticking.
Unlike the original google case its fit very nicely. Even after taking out the case few times it stick and for very.
chanbri
I'm using a cheap clear case which has no adhesives. Imak brand. ~$10 only. Just to protect the phone till I get a better one.
The privacy film I got from tech store at causeway point cost $25. I feel it's just meh for the price. Even my son told me he can still see from the side a bit.
Hayzzz isheeps are spoilt for choice. The whole store has 80-90% iphone cases and only 1 Google pixel 9 pro fold case.
I've ordered a thinborne but still looking around for a good screen protector. Privacy if possible.
chanbri
Casetify has a wide range of design for cases. But I already use casetify for my iphones and before on my galaxy fold 4. I find it too thick now. I've gravitated to Pitaka on my Samsung S23Ultra and Google Pixel 9 pro. It's sold out for the 9 Pro Fold though.
I'm getting more careful with my phone's over the years so I am not dropping them as much as before. Thus switching to thin aramid case is better. I've tried using phones naked or Dbrand skin only. But phones still get scratched easily even by other phones. Specially if you carry 2 phones in one pocket sometimes. The iphone camera specially can scratch my other phone screen just by rubbing....
joesph
Bros. How do i go about adding all apps from the app drawer all at once to home screen?
I'm aware of adding an app individually (i.e. swipe up at home screen and app drawer appears, long press the selected app and drag from app drawer to home screen). But with 80+ apps, appreciate any advice to do so quickly than repeating 80+ times! Thanks!
for years i couldn't find out how to do that. i use nova then make grid many, all apps can on one page. later i just use stock pixels' launcher. (dev option you make Smallest Width big number when you open app drawer can see more apps, learned from computerworld)
Sensational
Omg actually I also had the same issue with the mous case. But I think you never fit it in properly. You have to snap the front protector in one but it would totally damage the screen protector already. I did that twice and same issue. If not the left bottom side is like sticking upwards
Sensational
I saw on reddit that you can actually use the pixel 9 / 9 pro privacy tempered glass if you using case.
ForumRider
Then the case cannot fit with screen protector right? Its very different from the google original case
GeSteSoh
You don't add individually... Can use the above Home Settings, to NOT remove them from homescreen, as you install the apps.
