Honor Magic V3
aw1007
For those having difficulty to display YouTube 6 tiles in landscape and 4 tiles in potrait mode may try below trick ...
YouTube apps- app info-advance- untick the force full screen display
Ray1976
Honor has started rolling out Magic OS 9.0 (riding on Android 15) for selected handsets. Let's hope that it will be coming to global set soon.
NeonX
hopefully this year haha. If they can get it out by nov i'll be very impressed
tellim
Is it only me? Selfie taken from V3 look very fair..I disabled beautify function.
And also..v3 cannot auto blur background from object? The tool only allows circle or rectangle area not to blur....so inflexible
aw1007
You meant the potrait mode?
DeMoN7
I don't think the notifications can go to parallel space and vice versa. Individual space notifications only
Tks tks, asking cos my previous xiaomi is able to. Guess I have to find some ways to mitigate. Cheers
kaiser_11
Hi all,
Question regarding scanning QR codes. I don't seem to be able to scan the QR codes that are saved as screenshots into the gallery. Does anyone have any advice or instructions?
Cheers.
glorygoh
you have the aqara app at both spaces? dunno why mine in parallel space refuses to load then it will crash back to home screen
Yeah, after u mentioned it, I tried Aqara in parelle space and mine works flawlessly, even full screen works too.
tweety_piyo
you need it to run on both space? so far using it on normal page is fine for me.
cause i got some devices on SG server some on CN server ...if i need to make changes to any of them need to switch lor ...was thinking if i can have 2 separate aqara apps then no need keep switch servers
Ray1976
Hi all,
Cheers.
It's app dependent. What app is trying to use the QR code scanning?
kaiser_11
I was trying to add a contact with a Telegram QR code. I opened the camera app for QR code scanning and there is no option in there for me to pick an image via Gallery to scan.
rampage_111
anyone can intro place to replace screen protector (outside)? i just dropped face down while folded.. screen is fine (very impressed), but the original film is tored.. so looking to change the sp.. not looking at diy cuz i cant change ffs:censored::censored:...
