loganrunning
Even if I try out only, I will have to buy router with the usb tethering capability leh. Even with Singtel router, my bedroom is already a dead zone
to put it diplomatically, singtel routers are not quite up there......
if dead zone, consider an AP, can use repurposed singtel router.
kinda off topic here - suggest the networking clinic eg singtel thread
The_Davis
High Honorary Member
Deluxe Member
Oh then I ask you ah… if put the SIM card in old mobile phone and do hotspot, the network can extend very far? Coz my house is HDB maisonette
Coz usually mother will be upstairs then father will be downstairs
Buy sim router, connect wan to existing routers. Setup the router as AP then should be good to go?
~sabaisabai~
you can do a test first...
but using mobile to do tethering, battery drain up very fast
NovelLobster
Get the $18 at least got 588gb
I have to first sort out this question:
My robot vacuum must use 2.4ghz network. So if I put in 4G SIM card to 4G router, will I be able to still connect my robot vacuum to the network?
i don’t know how to translate mobile network to ghz band… I tried searching but cannot find the answer
The_Davis
Deluxe Member
Connect 4g “router” to your existing router.
the 4g router act as modem.
Otherwise, configure the 4g router 2.4ghz or 5ghz ssid bands.
sallybee
What kind of 4g router would you guys recommend ? I’m open to explore the above said ideas too
NovelLobster
Oh yah… you bought eight plan for home internet? Does the SIM card work with the router, plug and play? Or have to configure APN settings on the router?
my father wants to buy the TP-Link X50-4G+. I can’t find any info online if eight SIM card will work with it
The_Davis
Deluxe Member
Mine is plug n play. After reboot will connect automatically
JAYSCS
one consideration is to use "unlimited" data plans eg zero1 starter. if it's just streaming video, the throttled speed may be ok. that way, no need to mesasure data consumption.
(the TPG trial had 2GB a day, then unlimited at throttled speed. it was ok for streaming videos/movies)
Don't be deceived by unlimited throttled speed, it is limited but not indicated in the terms and conditions. MyRepublic 356kbps throttled speed data will be stopped once it excceeds 5GB, Zero1 1mbps will slow to 512kpbs then to 128kpbs then stop altogether after exceeding certain GB of data. SIMBA(Senior Plan) and Vivifi I had not tried though. Given data plan is so affordable nowadays, so-called unlimited throttled speed plan is irrelevant and merely just gimmicks.
gapboy
Switch to eight and get $8/$18 FREE credit
https://www.eight.com.sg/faq-promotion
  • What is this promotion about?
    Simply port-in your existing number to us and get $8/$18 credit. No promo code needed! This promotion applies only port-in customers
    • Port in to $8 plan: Get $8 credit in your eight wallet
    • Port in to $18 plan: Get $18 credit in your eight wallet
    The credit will be credited into your account within 7 working days. To learn more on this promotion head to our terms & conditions page. (https://www.eight.com.sg/termsofservice)
It is available both online and offline! Visit www.eight.com.sg/where-to-buy to visit our retailers.
  • Is there a promotion code to enjoy this?
    No promotion code! Enjoy a fuss-free experience with eight. The credits will be credited into your account within 7 working days. To learn more on this promotion head to our terms & conditions page. (https://www.eight.com.sg/termsofservice).
sango65
not bad, effectively 1-mth free, so use for 2 mths, then port out and port-in again if next time have promotion again :ROFLMAO:
amazingone
More porting issues coming ahead...
