chooyoshi
- Dec 29, 2016
From November 1st, Aussie telcos are mandated to block any device deemed "incompatible" with dialling emergency calls over VOLTE from their network, including voice, data and calls (since 3G is currently in the process of shutting down).
In other words, there is a chance that purchasing tourist SIM cards may no longer work! (particuarly if you use a phone brand not sold there, e.g. Vivo, Sharp, Sony, Honor)... SO MAKE SURE that after getting your SIM card in Australia, make sure your device isn't auto-blocked!
Not to mention the system for determining compatibility is inaccurate, thus some phones may be blocked wrongly.
While roaming circumvents this problem, there is still a chance voice calls may not go through within AU, even if your phone supports volte locally.
Thus, the best solution right now is to buy a phone in AU to use with your AU SIM. (so that you can receive/make phone calls when necessary, you can hotspot it to your local phone). The airport counters should stock some options, but you will have more options in town, from shops like JB Hifi, Officeworks and Harvey Norman. (prices start from 99AUD for a smartphone, but IMO try and budget at least 200+ AUD for a decent experience.)
Obviously, don't forget to bring it with you next trip, until something is done about the block at least.
Source: (Poster has testified many times to AU govt about the dangers of 3G shutdown to no avail).
This forum has "on the ground" info on the 3G shutdown, worth paying attention to.
