Kitaro9202
- Aug 24, 2007
Mine kena last year lor accidentally enable auto update den kena liao
Using 8 pro
Using 8 pro
Reno 8 Pro is it? Wah Oppo phone OS update also will kena... thot only Samsuck phones...Mine kena last year lor accidentally enable auto update den kena liao
Using 8 pro
One plus 8pro lorReno 8 Pro is it? Wah Oppo phone OS update also will kena... thot only Samsuck phones...
Causing using samsuck oledthot only Samsuck phones...
suay.. No choice. Your phone is samsuck oledOne plus 8pro lor
Awesome! Lucky my phone is non Samseng screen.Causing using samsuck oled
https://oledera.samsungdisplay.com/eng/oledfinder/
Also must see luck.Awesome! Lucky my phone is non Samseng screen.
Mine is China Oled screen also kenna green line after 11 months, now use it for alarm clock & surfing Shopee app at home.Also must see luck.
- Sometimes other oled provider also same issue thought majority are attributed to samsux panel
- The link i provided was recently released by Samsung Display so some of the older phones or maybe newer phones may not be accurate
- Manufacturer don't really release their panel manufacturer names so it is hard to find unless you find a youtuber or X (twitter) breakdown
Never go repair?Mine is China Oled screen also kenna green line after 11 months, now use it for alarm clock & surfing Shopee app at home.
Mine was export set with 6 months shop warranty bought from Shopee. So no point repairing it.Never go repair?
I had my first run in with green line this year and so discovered that my oppo actually used a samsux oled but luckily had 2 years warranty and they were quick to fix it no questions asked.
Is it using Samsuck oled?So OP12 has a chance of getting green line??
Yes. While OP12 uses BOE panels, there is also a chance of getting green line.So OP12 has a chance of getting green line??
Not nesscarily samsuck only.Is it using Samsuck oled?
I know but using samsuck one would have higher chance of getting the issue mah..Not nesscarily samsuck only.
Alot of speculation but you get the usual stuff if you searched onlineI know but using samsuck one would have higher chance of getting the issue mah..
So does software update on phones that use Samsuck oled cause the issue also?
Yeap, the same panel on the Fold 4 - Samsung Eco² OLED PlusFrom what I saw gt 7 pro uses Samsung OLED.. think I need to hesitate for green line issues down the line
Yes if is local set, My X3Pro also kena last year, 1 month before warranty expire.xiao.. my find x5pro show green line.
still under warranty.
Will oppo service centre service it?
Wow. thanks for the tipsYes if is local set, My X3Pro also kena last year, 1 month before warranty expire.
Just take note after screen replace, make sure you finger print sensor is working else will like me had to go back second time to let the technician enable back the sensor.
