- Aug 8, 2012
POCO Pad finally release in SG and showing up in Shopee.
https://shopee.sg/product/178877216/28016155883
POCO Pad [Sales start on 6 November]
-Storage:8GB+256GB
-Color:Black/Blue
Specs Highlights:
-12.1" 120Hz 2.5K display
-Snapdragon® 7s Gen 2 mobile platform(4nm)
-10000mAh battery+33W fast charging
-Quad speakers for immersive stereo sound
-Dolby Vision® and Dolby Atmos® supported
-Powered by Xiaomi HyperOS
Package Contents:
Tablet Computer / Adapter /USB Type-C Cable / Quick Start Guide /Warranty Card / SD Card Eject Tool
*Contents in the package may differ across different regions.
https://www.po.co/global/product/poco-pad/
Dimensions
Height 280.00mm
Width 181.85mm
Thickness 7.52mm
Weight 571g
Processor
Snapdragon® 7s Gen 2 Mobile Platform
4nm Process
CPU: Octa-core, up to 2.4GHz
GPU: Qualcomm® Adreno™ GPU
Storage & RAM
8GB+256GB
LPDDR4X+UFS 2.2 Supports expandable storage: Up to 1.5TB
*Configurations available may differ between different regions. Available storage and RAM are less than the total memory due to storage of the operating system and software pre-installed on the device.
Display
Size: 12.1", 16:10 aspect ratio
Resolution: 2560 x 1600 249 ppi
Material: LCD
Refresh rate: 120Hz AdaptiveSync (30/48/50/60/90/120Hz)
Brightness: 500 nits (typ); 600 nits (HBM)Touch sampling rate: up to 240Hz *240Hz is based on using Redmi Smart Pen
Screen-to-body ratio:83.6%
Contrast ratio: 1500:1
Color depth: 12-bit, 68.7 billion colors
Dimming: 4096 levels brightness adjustment, DC dimming
Dolby Vision®
Adaptive colors
Adaptive reading mode
TÜV Rheinland Low Blue Light (Hardware Solution) Certified
TÜV Rheinland Flicker Free Certified
TÜV Rheinland Circadian Friendly Certified
Corning® Gorilla® Glass 3
Camera
Rear camera8MP1/4", f/2, 1.12μm1080P 1920x1080 30fps720P 1280x720 30fps
Front camera
8MP1/4", f/2.28, 1.12μm1080P 1920x1080 30fps720P 1280x720 30fps
Battery&charging
10000mAh (typ), 9800mAh (min)
Supports 33W* fast charging
*33W wired charging means the adapter output power is 33W.
Actual power output may vary depending on the environment.
USB Type-C
Data transfer
USB 2.0*USB 2.0 functionality requires a USB 2.0 enabled cable (sold separately).
Connectivity
Wi-Fi 6,Wi-Fi 5,Wi-Fi 4 and 802.11a/b/g2.4GHz Wi-Fi | 5GHz Wi-Fi
Supports 2x2 MIMO, Wi-Fi Direct, Miracast, MU-MIMO
Bluetooth 5.2AAC /LDAC/SBC/aptX/aptX-HD/aptx-adaptiveIPv6
Sensors
Accelerometer | Gyroscope | Ambient light sensor | Color temperature sensor | Electronic compass | Hall sensor
Operating System
Xiaomi HyperOS, Android U
Package contents
-Storage:8GB+256GB
-Color:Black/Blue
Specs Highlights:
Package Contents:
Dimensions
Height 280.00mm
Width 181.85mm
Thickness 7.52mm
Weight 571g
Processor
4nm Process
Storage & RAM
8GB+256GB
Display
Material: LCD
Dolby Vision®
Adaptive colors
Camera
Front camera
Battery&charging
USB Type-C
Data transfer
Connectivity
Sensors
Operating System
Package contents
