- Sep 16, 2018
Or using nft command.
Bash:
root@OpenWrt:~# nft list ruleset
table inet fw4 {
chain input {
type filter hook input priority filter; policy drop;
iifname "lo" accept comment "!fw4: Accept traffic from loopback"
ct state established,related accept comment "!fw4: Allow inbound established and related flows"
tcp flags syn / fin,syn,rst,ack jump syn_flood comment "!fw4: Rate limit TCP syn packets"
iifname { "eth2", "br-lan", "wg_lan" } jump input_lan comment "!fw4: Handle lan IPv4/IPv6 input traffic"
iifname "eth1" jump input_wan comment "!fw4: Handle wan IPv4/IPv6 input traffic"
jump handle_reject
chain forward {
type filter hook forward priority filter; policy drop;
ct state established,related accept comment "!fw4: Allow forwarded established and related flows"
iifname { "eth2", "br-lan", "wg_lan" } jump forward_lan comment "!fw4: Handle lan IPv4/IPv6 forward traffic"
iifname "eth1" jump forward_wan comment "!fw4: Handle wan IPv4/IPv6 forward traffic"
jump handle_reject
chain output {
type filter hook output priority filter; policy accept;
oifname "lo" accept comment "!fw4: Accept traffic towards loopback"
ct state established,related accept comment "!fw4: Allow outbound established and related flows"
oifname { "eth2", "br-lan", "wg_lan" } jump output_lan comment "!fw4: Handle lan IPv4/IPv6 output traffic"
oifname "eth1" jump output_wan comment "!fw4: Handle wan IPv4/IPv6 output traffic"
chain prerouting {
type filter hook prerouting priority filter; policy accept;
iifname { "eth2", "br-lan", "wg_lan" } jump helper_lan comment "!fw4: Handle lan IPv4/IPv6 helper assignment"
chain handle_reject {
meta l4proto tcp reject with tcp reset comment "!fw4: Reject TCP traffic"
reject comment "!fw4: Reject any other traffic"
chain syn_flood {
limit rate 25/second burst 50 packets return comment "!fw4: Accept SYN packets below rate-limit"
drop comment "!fw4: Drop excess packets"
chain input_lan {
ct status dnat accept comment "!fw4: Accept port redirections"
jump accept_from_lan
chain output_lan {
jump accept_to_lan
chain forward_lan {
tcp dport 853 counter packets 668 bytes 46488 jump handle_reject comment "!fw4: ubus:adblock-fast[main] rule 1"
udp dport 853 counter packets 0 bytes 0 jump handle_reject comment "!fw4: ubus:adblock-fast[main] rule 1"
tcp dport 853 counter packets 0 bytes 0 jump handle_reject comment "!fw4: ubus:https-dns-proxy[instance1] rule 1"
udp dport 853 counter packets 0 bytes 0 jump handle_reject comment "!fw4: ubus:https-dns-proxy[instance1] rule 1"
jump accept_to_wan comment "!fw4: Accept lan to wan forwarding"
ct status dnat accept comment "!fw4: Accept port forwards"
jump accept_to_lan
chain helper_lan {
chain accept_from_lan {
iifname { "eth2", "br-lan", "wg_lan" } counter packets 137658 bytes 11106459 accept comment "!fw4: accept lan IPv4/IPv6 traffic"
chain accept_to_lan {
oifname { "eth2", "br-lan", "wg_lan" } counter packets 10887 bytes 814895 accept comment "!fw4: accept lan IPv4/IPv6 traffic"
chain input_wan {
meta nfproto ipv4 udp dport 68 counter packets 0 bytes 0 accept comment "!fw4: Allow-DHCP-Renew"
icmp type echo-request counter packets 123 bytes 5527 accept comment "!fw4: Allow-Ping"
meta nfproto ipv4 meta l4proto igmp counter packets 1004 bytes 32128 accept comment "!fw4: Allow-IGMP"
meta nfproto ipv6 udp dport 546 counter packets 1 bytes 209 accept comment "!fw4: Allow-DHCPv6"
ip6 saddr fe80::/10 icmpv6 type . icmpv6 code { mld-listener-query . no-route, mld-listener-report . no-route, mld-listener-done . no-route, mld2-listener-report . no-route } counter packets 1004 bytes 76304 accept comment "!fw4: Allow-MLD"
icmpv6 type { destination-unreachable, time-exceeded, echo-request, echo-reply, nd-router-solicit, nd-router-advert } limit rate 1000/second counter packets 52 bytes 3328 accept comment "!fw4: Allow-ICMPv6-Input"
icmpv6 type . icmpv6 code { packet-too-big . no-route, parameter-problem . no-route, nd-neighbor-solicit . no-route, nd-neighbor-advert . no-route, parameter-problem . admin-prohibited } limit rate 1000/second counter packets 2524 bytes 181728 accept comment "!fw4: Allow-ICMPv6-Input"
udp dport 51820 counter packets 0 bytes 0 accept comment "!fw4: Allow-WireGuard-lan"
jump reject_from_wan
chain output_wan {
jump accept_to_wan
chain forward_wan {
icmpv6 type { destination-unreachable, time-exceeded, echo-request, echo-reply } limit rate 1000/second counter packets 0 bytes 0 accept comment "!fw4: Allow-ICMPv6-Forward"
icmpv6 type . icmpv6 code { packet-too-big . no-route, parameter-problem . no-route, parameter-problem . admin-prohibited } limit rate 1000/second counter packets 0 bytes 0 accept comment "!fw4: Allow-ICMPv6-Forward"
meta l4proto esp counter packets 0 bytes 0 jump accept_to_lan comment "!fw4: Allow-IPSec-ESP"
udp dport 500 counter packets 0 bytes 0 jump accept_to_lan comment "!fw4: Allow-ISAKMP"
jump reject_to_wan
chain accept_to_wan {
meta nfproto ipv4 oifname "eth1" ct state invalid counter packets 1010 bytes 46198 drop comment "!fw4: Prevent NAT leakage"
oifname "eth1" counter packets 86305 bytes 22440542 accept comment "!fw4: accept wan IPv4/IPv6 traffic"
chain reject_from_wan {
iifname "eth1" counter packets 12771 bytes 817150 jump handle_reject comment "!fw4: reject wan IPv4/IPv6 traffic"
chain reject_to_wan {
oifname "eth1" counter packets 0 bytes 0 jump handle_reject comment "!fw4: reject wan IPv4/IPv6 traffic"
chain dstnat {
type nat hook prerouting priority dstnat; policy accept;
iifname { "eth2", "br-lan", "wg_lan" } jump dstnat_lan comment "!fw4: Handle lan IPv4/IPv6 dstnat traffic"
chain srcnat {
type nat hook postrouting priority srcnat; policy accept;
oifname "eth1" jump srcnat_wan comment "!fw4: Handle wan IPv4/IPv6 srcnat traffic"
chain srcnat_wan {
meta nfproto ipv4 masquerade comment "!fw4: Masquerade IPv4 wan traffic"
chain raw_prerouting {
type filter hook prerouting priority raw; policy accept;
chain raw_output {
type filter hook output priority raw; policy accept;
chain mangle_prerouting {
type filter hook prerouting priority mangle; policy accept;
chain mangle_postrouting {
type filter hook postrouting priority mangle; policy accept;
chain mangle_input {
type filter hook input priority mangle; policy accept;
chain mangle_output {
type route hook output priority mangle; policy accept;
chain mangle_forward {
type filter hook forward priority mangle; policy accept;
iifname "eth1" tcp flags syn tcp option maxseg size set rt mtu comment "!fw4: Zone wan IPv4/IPv6 ingress MTU fixing"
oifname "eth1" tcp flags syn tcp option maxseg size set rt mtu comment "!fw4: Zone wan IPv4/IPv6 egress MTU fixing"
chain dstnat_lan {
tcp dport 53 counter packets 2572 bytes 154320 redirect to :53 comment "!fw4: ubus:adblock-fast[main] redirect 0"
udp dport 53 counter packets 123984 bytes 9683892 redirect to :53 comment "!fw4: ubus:adblock-fast[main] redirect 0"
tcp dport 53 counter packets 0 bytes 0 redirect to :53 comment "!fw4: ubus:https-dns-proxy[instance1] redirect 0"
udp dport 53 counter packets 0 bytes 0 redirect to :53 comment "!fw4: ubus:https-dns-proxy[instance1] redirect 0"
table ip ts-test-nat {
