i doubt govt will push for more than 10g in residential since all bto house only have CAT 6 LAN pre-installed..unless future BTO start having CAT 8 or SFP ports pre-installed![]()
WL-NWU340G Rev. A. For your issue, have you tried it with any other windows laptop etc? What do you mean by instability? For me, after system bootup, it takes about 1-2 seconds to initialise and then i am connected to LAN.
Not sure if it'll help but i'm running 13900k/ MSI Z790i Edge desktop, as well as 7840HS Lenovo Slim 7 laptop. Both works fine.
Try the OEM drivers from Realtek at: https://www.realtek.com/Download/List?cate_id=585I am using Beelink Ser7 (AMD7840HS). Plugged the wavlink WL-NWU340G (A) into the USB4 port and getting only 1Gbps for download and 4.3Gbps for upload. Installed the driver downloaded from Wavlink and restarted the pc. Result is the same. The generic lan port on this mini pc is 2.5Gbps and I got about 2.3Gbps.
Will try another laptop to see if it makes another difference. Hiaz...
I just got the XikiStore USB4/TB4/TB3 to 10G RJ45 NIC (Marvell AQC107 chipset), model SKN-T310GT.
Their own video says that it has a fan and some users may not like it. Indeed I will say I do not like it as the fan noise is quite audible.
NOT recommended because of the fan noise.
I am not so sure why they need to put a fan. It is actually taller than my other two USB4/TB4/TB3 10G NIC from IOCrest and GRiS (these two have the same size and no fan). The good thing about XikeStor is that the 10Gbe RJ45 port is in the other side of the adapter. IOcrest/GRiS version have the 10Gbe RJ45 port next to the USB 4 port.
The build quality and packaging are actually better than IOcrest and GRiS, if I just look from the outside (not going to tear down).
SpeedTest with my Acer Swift 3 early 2021 laptop (Intel Core i5-1135G7 CPU, 16GB/512GB, latest Windows 24H2), Singtel 5Gbps plan
Does the fan helps by keeping the tmeps in checks?
Just got my WAVLINK adapter delivered. I'm actually surprised they delivered it on Sunday.
Starhub 5Gbps ONT > Deco BE85 > Wavlink 5Gbps
Nice, a bit better than my result using Wavelink USB Type C 5Gbe adapter, Singtel 5Gbps plan, Acer Swift 14 Go OLED version (Intel Core Ultra 125H).
https://forums.hardwarezone.com.sg/threads/5gbe-and-beyond-ethernet-adapters.7068236/page-4
I brought the same thing and was setting it up yesterday evening.I just got the XikiStore USB4/TB4/TB3 to 10G RJ45 NIC (Marvell AQC107 chipset), model SKN-T310GT.
Server: PT Indosat Tbk - Singapore (id: 13058)
ISP: StarHub
Idle Latency: 3.16 ms (jitter: 0.55ms, low: 2.35ms, high: 3.68ms)
Download: 496.34 Mbps (data used: 487.0 MB)
2.93 ms (jitter: 5.43ms, low: 2.10ms, high: 223.14ms)
Upload: 2187.87 Mbps (data used: 2.4 GB)
2.89 ms (jitter: 0.39ms, low: 2.18ms, high: 7.05ms)
Packet Loss: 0.0%
Being lurking around for a while now. Thanks everyone for your generous sharing.
I signed up for the SH 5Gbps $29.55 monthly special deal when my existing contract is over.
This is my speed test results. I would expect both Download and Upload to be somewhere near 2Gbps?
I connected to Nokia router 10GbE port via a 2.5Gbps Ethernet adapter on a Thunderbolt (USB-C interface) on my laptop. I'm using CAT 6 LAN cable.
Thanks in Advance.
Hi bros, I read this thread but catch no ball leh.
I just signed up to Starhub 10 gbps plan and got the TP-Link HB710 router from them. I am directly connecting a Cat6A cable from the router’s 10 gbps port to my PC mobo, which has a 2.5 GbE LAN port.
What is the best solution/upgrade I need for my PC to utilise the 10 gbps on my PC?
Do you have empty PCI-E x4 slot?
If yes, buy a 10G NIC mentioned in the first page (Intel X550 based adapter is recommended).
Would something like this work?
TP-Link 10Gbps LAN Card PCI-E Adapter Network Card TX401
PCI-E adapters using Marvell AQC107/AQC113C chipset may have issues under Windows.
TP-Link TX401and Asus XG-C100C are the most notorious 10G network adapters in this forum under Windows. Both are using Marvell AQC107/AQC113C chipset. Some users have to reinstall Windows to get the right speed.
They are usually fine under Linux. So I will say it is partially Windows problem, partially Marvell problem.
