- Mar 22, 2011
that's a good price, really have to look around. Yesterday, i went to different CEIT stores, each quoted me high price, till i tell them Sony Store offered the best price, then they do price match. Where did you see 4399 from?oted $4399 for black friday price, it is m
Was comparing both side by side X90L vs Bravia 7, i have to say that Bravia 7 has less reflections than X90L. My living room is always super bright, hence will need bright ones like Bravia 7. Thanks, extended warranty from these retailers is really a good assurance. Will consider thatIf u are still hesitating between X90L and Bravia 7... just close eyes and hoot Bravia 7 with no regrets.
The reflection issue is not really a big problem in bright room.
TV Speakers still able to handle daily use. But if u want the bass/impact, do purchase a soundbar or speakers system to enhance your experience.
Picture quality and colors are quite ok out of the box with no calibrating.
Google TV OS works as it is - with popular apps installed - youtube, disney+, prime, netflix. If you want to surf internet, u may download internet browser app and install with ease due to Google TV OS built-in.
3yrs warranty direct via Sony.
However, if u buy via HN, Courts, Gaincity and purchase their extended warranty - this means after 3rd year - got any issues - u have to call the retailer and they will notify Sony tech to come rectify.
that's good, not much blooming as X90L, due to more local array dimming and the mini-LEDs. I was looking at Bravia8 too, tempting, but no. It's not ideal for my bright living room, even the sony salesman at sony store, recommend Bravia 7 over Bravia 8 for my use case.Have had the 75 " Bravia 7 for the last 1-2 months.Installed in the living room.
Not using the Native TV apps . Have my Nvidia Shield TV pro 2019 connected to it.
Apps used - Youtube ( unfortunately the Shield lacks the HDR support for Youtube - but it looks fab anyways ) , Disney + , Netflix , Prime Video US (VPN).
Settings https://www.rtings.com/tv/reviews/sony/bravia-7-qled/settings
- Professional mode under the Picture settings and then increase/decrease brightness depending on the room.I have my brightness at 15.
- Dolby Vision bright for those apps that support
Its just remarkable how nice the panel looks .
I don't see much/if ANY blooming ( had a 2012 model 55 " Sony and it bloomed like crazy esp at life end )
Sound quality - ok I guess but I cant stand TV sound.it's a thin panel after all.
Have the TV connected to a set of small active speakers + an SVS subwoofer.
I did see the 65" Bravia 8 ( OLED ) side by side in store at Best Denki Vivocity and was very tempted since the blacks and contrast are definitely better but the Organic part of OLED and potential for burn in scares me.So I decided to upsize and got a decent enough deal on the 7.
Highly recommend!!
I also tried the tv speakers for Bravia 9, i was super impressed with that.
