CIMB FastSaver
sglandscape
just to chk, using posb si to transfer $1k every mth, to have $5k bal from 7 dec 2024. my 30 nov bal is $0.
i will get 3.7% till 28 feb 2025 + $150 on 31 jan 2025?
Not sure what you're trying to get clarification for, cause have 3 different promos CIMB has, and only 2 requires SI and one requires the 5k incemental balance
wutawa
i am chking if i miss out any requirements for getting 3.7% till 28 feb 2025 + $150 on 31 jan 2025.
sglandscape
You can only get 3.7% for the first 25k. You need to set up monthly SI of minimum 1k each month. The 150 you only get if you've not done in the previous promo.
To get base of 3.2% you need 5k incemental balance vs end of Nov if you're just taking part this month.
The tnc is very clear if you actually do read it, incase you missed something.
wutawa
last time need to send whatsapp msg to register. now more straightforward.
i only have 5k + 1k mthly. getting the 3.7% for 2+ mths and $150 a lot. mari savings only gives 2.7%.
sglandscape
Just make sure you keep the 5k incemental balance, not just 5k balance for all the days I'd not you may not get the 3.2% base interest.
sgdividends
For the Dec , Jan and Feb promo of 3.2%pa if all conditions are fulfilled..actually some tier is 3.3% pa as prevailing rate already. Does this mean the prevailing rate is ignored and only 3.2%pa is applied on the total incremental balance ?
wutawa
No, the website shows 3.3% will apply.
yiron
Seems like starsaver is better than fastsaver if one has lots of money because fastsaver only 3.3% pa on a 25k tier but starsaver is 3.3%pa on uncapped amount above 250k
Yup, for balances below $250k, Fastsaver is slightly better due to a block of $25k getting 3.3%. Beyond $250k, Starsaver starts to outperform with 3.3% incremental rate.
tiertime
The CSO just told me that for the 3-month bonus interest campaign, need to have min 5k on the LAST DAY of the 3rd month ,
else can say byebye to the 3.2% interest for the WHOLE of the 3 months
If on any days before the Last day can withdraw till balance zero is also ok, only Last day must hv the 5k
wutawa
Thanks for sharing this hidden condition.
