Japan sim card?
manaeater
anyone used the Klook-bought SIM cards before?
Is it more than sufficient? Cheaper compared to buying after arrival?
Thank you!
class
I came back from Tokyo 10 days. Used google maps, apple map and Disney.
used simba 7gb+ a bit more
weekendz
any physical sim card to recommend ar? landing at haneda terminal 2 but most klook sim card is pick up at haneda terminal 3 :cry:
rrr2015
why not pickup from changi recommend or ICC from shopee? i think any docomo or softbank should be good. never have luck with kddi
elbib00
Just came back. Used a sim card from shopee without any issues. But can't used for voice calls
megaweb
Is this good?
Good enough for me and my family members. It allows us to navigate via google map.
Initially encounter no data connection, check with the seller, he advised me to include APN name. After configure APN name, connection was working.
zoossh
Good to have but not neccesary. Only time you may need the voice is to reserve restuarants seats. But this can be solved by asking your hotel to help.
Mobal the only one with call? It’s very expensive
concreteman
the free esim from klook is good enough for google maps and email. can save hassle of buying esim/sim card if you buy attractions or transport from klook
123xyz
Anyone use M1 Daily Passport overseas roaming instead of Japan SIM in Tokyo? was wondering how is the network speed and connectivity compared to Japan SIM
