[Software Update] iOS 18.7.2 is out!
ragnarok95
Senior Moderator
Senior Moderator
I am using iPhone 16pm
Now when I press the side button, the Siri button came out instead of the rainbow color boundary around the edge :(
Mine is still the rainbow siri. long press power right?
twosix
Siri is still not the final product right? Asked a simple weather forecast and nothing has changed.
Jirachi
Are you not able to change language and re-download AI? This should work.
Jirachi
I am now hoping that the system will auto purge the downloaded Apple Intelligence that I accidentally enabled.
zorrus
Moderator
Moderator
I found out why. It’s because even after upgrade to 18.2, there are still background download for the apple intelligence hence I thought it was gone
iosnewbie
the Playground app still needs a lot more work. At this release, can only add one person’s pic plus other scenarios. Cannot add persons pics or a single pic with more than one person inside.
Singrish
Mine shows ios 18.2 and US English with apple intelligence on but no image playground app on home screen.
Edit: I was out earlier. When i went home & logged onto wifi suddenly it showed image playground but when i tried to run it opened app store then said not available in my country & i never saw it again. 🙄
Apple Intelligence works on my iphone so my language setting confirm correct.
duabuiji
if ur display is set to zoomed, the top right corner icons will get blocked by dynamic island. this bug is still unsolved. comeon, this is already 18.2. seems apple got no intention to fix this.
