Vivo X200 Series
Computeron
Full square, quite shiok leh once get used to it haha.
tat time I from sq change to 16:9... now how to change to sq?
tat time I found fault when using sq.. I forgot wat... izzit sides are cropped.. top n bottom more view?
donno izzit peeping map hard or wat..
Daruul
staff at melaka say they won't bring ultra in... but might bring the blue version of either non-pro/pro in 6 to 7 mths time
lanzhu60
any recommended eshop to buy? u guys all using china rom? does ms authenticator and work profile works?
nom.nom
Tested the Pro in Hongkong (and comes with play store)
photography looks better than OPPO one this time.
but Laz or Shopee cheaper.
menace66
Hi guys. I am really enticed to switch over to the X200 Pro from my current S23 Ultra and the China ROM phones offer more value than the global ROM models. Before I take the plunge, can someone help to clarify if the following apps will work? My workplace is very big on info security so I am a bit on the fence.
The 1st 3 apps below are pre-requisites for the rest of the MS apps to work for me. Thank you very much.
- Microsoft Company Portal
- NetIQ Authenticator
- Okta Verify
- MS Teams
- MS Outlook
- MS Onedrive
- MS OneNote
