Vivo X200 Series
KeYoKe
Hi guys. I am really enticed to switch over to the X200 Pro from my current S23 Ultra and the China ROM phones offer more value than the global ROM models. Before I take the plunge, can someone help to clarify if the following apps will work? My workplace is very big on info security so I am a bit on the fence.
The 1st 3 apps below are pre-requisites for the rest of the MS apps to work for me. Thank you very much.
- Microsoft Company Portal
- NetIQ Authenticator
- Okta Verify
- MS Teams
- MS Outlook
- MS Onedrive
- MS OneNote
If you use intune, highly recommend to skip china firmware. Notifications will be an issue on work profile. Tested it on z9 turbo on originOS. Despite enabling auto start and disabling battery optimization, notifications still will not come in.
menace66
What a bummer. Guess I just have to fork out more and skip on the 1TB if I wanna get the phone. Appreciate the advise. Thank u.
KeYoKe
Yes. Get a global rom set if i rely heavily on work profile. Lucky i manage to see your post to stop u from purchasing.
eddy0505
Better check with your company if they got ban any brands/only limit to the mainstream brands. I know some they don't allow even with official global rom.
tomicaguy
Ray1976
Haven't decide whether to get yet...but if coming to Singapore, I may be tempted. :p
ahhe84
Hi guys is china rom sg app will having problems to use and even phone hardware update???
kryptonit3
sg app like singpass, banking, GPay no issues just notifications for WhatsApp, Instagram etc need set permissions.
no issues in receiving software updates for device.
frizee
Keep watching reviews but.. Didnt want to risk China ROM so decided to hoot 9PXL instead :D
kryptonit3
Mean no problem at all.. just need to set promise approve right??
I would suggest to go through the down sides of the china variant before jumping in to buy it. generally apps works but if you are power user that have plenty of communication apps that requires notifications would be a hassle to set them up 1 by 1. For me i’m using it as a secondary device so this is fine for me.
yukita
I concern of the warranty, and just now saw in Vivo fold 3 pro thread someone claim lazada insurance before. so I purchased the insurance as well.
