btw hows the battery life? i heard last 4 to 5 hour?Promo price I will said worth , problem is that you might not get the result you u wan for like example galaxy buds 2 u pass to every body ppl will describe it in similar matter
While Denon is purely dependent on it eq result and every result might be different
so far my eq result is pretty consistent but the sound u hear base on my result might be very different to yours and which one u like is totally another thing as it might not eq it to the way you like it
you may like your friend eq profile instead
Be warn for example it anc is still like early gen anc damm weak
shld have ah 4 hr + but nvr use until that much in one session psbtw hows the battery life? i heard last 4 to 5 hour?
did a search, Stereo sellingAnyone using the earfun air pro 4?looking to buy them thinking worth anot
How is your experience with Jabra elite 4? Popular having promo at $48Currently have Jabra Elite 4 & Liberty 4 NC
Can consider creative sxfiI sent in my creative zen airdots for repair. Only less than 6 months of usage. The earbuds leak charge, lose power very fast. Then cannot charge up anymore. Quite disappointed with it. I thought the local brand supposed to be of good reasonable quality.
I recommend soundcore or earfun too.I sent in my creative zen airdots for repair. Only less than 6 months of usage. The earbuds leak charge, lose power very fast. Then cannot charge up anymore. Quite disappointed with it. I thought the local brand supposed to be of good reasonable quality.
How much u bought i saw price quite steepPi8. Using on my Sharp phone with bluetooth 5.4 and supports snapdragon sound. Wonderful detail and resolution without harsh highs or sibilance. Bass is a bit too warm for my taste, turning down the bass in the app's EQ fixed that. Soundstage front and up down is wide, left right is slightly wide.
Any static sound when music not on?my denon pro perl just arrive gotta said i prefer az 80 more
denon pro perl have an thick bass line and solid imaging after personalized for quick impression
Around $670.How much u bought i saw price quite steep
no , yours have ? but the anc maybe need more test does not seem to capable to me .Any static sound when music not on?
Nah dont haveno , yours have ? but the anc maybe need more test does not seem to capable to me .
i dont expect this even for $3 tws.Any static sound when music not on?
