Fastest ISP?
fkchon
ViewQwest 1Gbps on ethernet
StarHub on WiFi 6
Seems like StarHub has better routing to Japan than VQ.
ieatcable
Quality routing > high bandwidth plan
If you often venture to overseas sites/servers without local cdn (eg not Google/facebook/tiktok/yt), you start to realise anything >1Gbps is pointless because firstly
1) overseas connection itself has a throttled bandwidth 2) most lag is cause by high ping and jitters, packet losses and throttling caused by low quality or congested routes
Singtel and M1 users can see for themselves what I mean here:https://proof.ovh.net/. Wait for the applet to load and choose any IPv4 EU location like Gravelines or Limburg run the test during peak period :s13:
Doesn't matter whether 1Gbps or 10Gbps when your speed is throttled to 200kb/s due to trash routes taken
1 Ghz
M1's IPV6 to Gravelines/Limburg seems to be 1000x faster than IPV4. o_O
seowbin
Night time , peak hour ? Tested from my mobile
ieatcable
Ya like right now moi also getting max 2Mbps down on M1 and singtel mobile. same result at 7pm using friend's singtel broadband
U test Singtel ah? semo IP block is yours
Different routing on ipv6. Ipv4 downlink go by Singtel upstream :yawn:
seowbin
No la. Not mainstream Telco. :s13:
Singtel, wireless from my laptop (Acer Swift 2021 model with Intel AX201 WiFi 6 adapter), Asus TUF-BE6500 wireless router (2.5Gbe WAN port). I am using Singtel 5Gbps plan.
Singtel ZTE F8648P ONR bridged 10G LAN port --> Intel N100 OpenWRT virtual router --> 2.5G/10G switch --> TUF-BE6500 router --> wireless --> Acer Laptop running Windows 11 24H2
Results: using IPv4 (42.60.xxx.xxx, Singtel AS9506), about 7:40am, Saturday 28-Dec-2024
https://www.nperf.com/en/r/3553981477976708-A6oNnhjy
BBCWatcher
On top of all of this, what’s the content and real-life situation? If for example it’s a 196 Kb/s stream of German opera, none of these measurements matter. Any of these test results will do fine. Your German opera stream will sound and perform exactly the same. In contrast, if you’re working for DW as a video editor and need to send and receive huge video recordings to/from Europe on tight deadlines, OK, maybe the quality and capacity of your ISP’s routes to Europe will matter — the fibre bandwidth into your home office, much less so. (How many people are DW video editors working at home in Singapore?)
Note that the Internet, especially internationally, is variable. With Russian and Chinese ships now intentionally dragging anchors to sever undersea links, expect some variable capacity constraints to certain destinations. And don’t worry about the fibre bandwidth into your home. Literally all contract offers, even the least expensive, are amazing in terms of how fast the link is between your home and NetLink Trust’s infrastructure.
@Mach3.2 will like this test very much.
Your VQ results are quite decent.
Singtel is so so so bad with this test. You can see my test results below, using WiFi (but WiFi should not be the real issue here -- got good connection using RT-AX86U router at 3m distance only.
https://www.meter.net/tools/world-ping-test/#0-35860-9cfdc6
The above test was done on 15-August-2024.
Now it is 28-Dec-2024. Still using wireless, 4m away from Asus TUF-BE6500. The results look better now.
Singtel ZTE F8648P ONR bridged 10G LAN port --> Intel N100 OpenWRT virtual router --> 2.5G/10G switch --> TUF-BE6500 router --> wireless --> Acer 2021 Laptop running Windows 11 24H2 (Intel Core i5-1135G7 CPU, 16GB/512GB, Intel AX201 WiFi 6 adapter)
Tested twice.
https://www.meter.net/tools/world-ping-test/#0-149276-9d03a2
https://www.meter.net/tools/world-ping-test/#0-149283-9af745
ieatcable
Interesting. There are different paths taken for different Singtel IP blocks.
42.60.254.x goes through london IX peer
Code:
HOST: gra.lg.ovh.net                                              Loss%   Snt   Last   Avg  Best  Wrst StDev
  1. AS16276  141.94.18.1                                          0.0%     3    0.4   0.3   0.1   0.4   0.1
  2. AS???    192.168.143.254                                      0.0%     3    0.4   0.4   0.3   0.4   0.1
  3. AS???    10.69.168.62                                         0.0%     3    0.5   0.6   0.5   0.7   0.1
  4. AS???    10.69.162.160                                        0.0%     3    0.5   0.6   0.5   0.7   0.1
  5. AS???    10.69.128.76                                         0.0%     3    0.4   0.6   0.4   0.7   0.1
  6. AS???    10.17.155.58                                         0.0%     3    0.8   1.0   0.8   1.2   0.2
  7. AS???    10.73.1.58                                           0.0%     3    0.5   0.5   0.4   0.6   0.1
  8. AS???    10.95.33.8                                           0.0%     3    1.1   1.1   1.0   1.1   0.0
  9. AS16276  lon-thw-sbb1-nc5.uk.eu (91.121.215.179)              0.0%     3    4.1   4.1   4.1   4.1   0.0
 10. AS???    10.200.0.131                                         0.0%     3    3.7   3.9   3.7   4.2   0.3
 11. AS???    195.66.237.10                                        0.0%     3    3.5   3.6   3.5   3.9   0.2
 12. AS7473   203.208.158.61                                       0.0%     3  171.3 173.8 171.2 178.9   4.5
 13. AS7473   203.208.158.161                                      0.0%     3  171.5 171.6 171.5 171.8   0.2
 14. AS7473   203.208.183.82                                       0.0%     3  171.9 171.7 171.6 171.9   0.1
 15. AS7473   203.208.177.214                                      0.0%     3  174.0 174.1 174.0 174.3   0.1
 16. AS3758   SN-SINQT1-BO117-ae4.singnet.com.sg (165.21.138.86)   0.0%     3  205.5 187.6 172.5 205.5  16.7
 17. AS3758   165.21.138.246                                       0.0%     3  174.4 181.0 174.3 194.4  11.6
 18. AS3758   165.21.193.22                                        0.0%     3  174.6 174.8 174.6 175.0   0.2
 19. AS9506   bb151-192-120-253.singnet.com.sg (151.192.120.253)   0.0%     3  172.7 172.8 172.7 173.0   0.2
 20. AS9506   bb42.60-254-1.singnet.com.sg (42.60.254.1)           0.0%     3  174.1 174.1 173.9 174.2   0.2
42.60.127.x goes through Zayo upstream
Code:
  1. AS16276  141.94.18.1                                     0.0%     3    0.5   0.4   0.4   0.5   0.1
  2. AS???    192.168.143.254                                 0.0%     3    0.6   0.5   0.4   0.6   0.1
  3. AS???    10.69.168.62                                    0.0%     3    0.7   0.6   0.6   0.7   0.1
  4. AS???    10.69.162.162                                   0.0%     3    0.6   0.7   0.6   0.8   0.1
  5. AS???    10.69.128.80                                    0.0%     3    0.7   0.7   0.6   0.7   0.1
  6. AS???    10.17.146.2                                     0.0%     3    0.8   0.8   0.8   0.9   0.1
  7. AS???    10.73.0.76                                      0.0%     3    0.8   0.7   0.5   0.8   0.2
  8. AS???    10.95.33.8                                      0.0%     3    1.5   3.6   1.5   7.6   3.5
  9. AS16276  be102.par-gsw-sbb1-nc5.fr.eu (91.121.215.177)   0.0%     3    5.7   5.3   5.0   5.7   0.3
 10. AS???    10.200.2.7                                      0.0%     3    5.5   5.3   5.1   5.5   0.2
 11. AS???    zayo.par.franceix.net (37.49.237.180)           0.0%     3   11.8   8.8   5.1  11.8   3.4
 12. AS6461   ae18.cr1.cdg12.fr.zip.zayo.com (64.125.26.68)   0.0%     3    8.2   7.9   7.8   8.2   0.2
 13. AS6461   213.161.72.106                                  0.0%     3    7.7   7.9   7.7   8.4   0.4
 14. AS7473   203.208.166.249                                 0.0%     3  165.9 165.5 165.2 165.9   0.4
 15. AS7473   203.208.158.9                                   0.0%     3  165.5 165.5 165.4 165.7   0.2
 16. AS7473   203.208.158.206                                 0.0%     3  165.5 165.6 165.5 165.6   0.1
 17. AS7473   203.208.143.130                                 0.0%     3  166.9 166.1 165.7 166.9   0.7
 18. AS3758   165.21.139.133                                  0.0%     3  165.6 165.7 165.6 165.9   0.1
 19. AS3758   165.21.139.170                                  0.0%     3  165.8 165.9 165.8 165.9   0.0
 20. AS3758   165.21.193.234                                  0.0%     3  166.9 171.6 166.1 181.9   8.9
 21. AS???    ???                                            100.0     3    0.0   0.0   0.0   0.0   0.0
 22. AS9506   bb42-60-127-1.singnet.com.sg (42.60.127.1)      0.0%     3  166.6 166.7 166.6 166.7   0.1
116.15.49.x is the one I've gotten and tested the result 2Mbps few post up. Goes through germany DE-CIX peer.
Code:
  2. AS???    192.168.143.254                              0.0%     3    0.4   0.5   0.4   0.5   0.1
  3. AS???    10.69.168.62                                 0.0%     3    0.4   0.6   0.4   0.7   0.2
  5. AS???    10.69.128.80                                 0.0%     3    0.6   0.6   0.6   0.7   0.1
  6. AS???    10.17.149.112                                0.0%     3    0.9   0.8   0.7   0.9   0.1
  7. AS???    10.73.0.122                                  0.0%     3    0.5   0.7   0.5   0.9   0.2
  8. AS???    10.95.33.10                                  0.0%     3    2.9   2.3   1.9   2.9   0.6
  9. AS16276  be10.fra-fr5-sbb2-nc5.de.eu (54.36.50.151)   0.0%     3    9.2   9.6   9.2   9.8   0.3
 10. AS16276  fra-fra15-sbb2-8k.de.eu (57.128.121.53)      0.0%     3   11.3  11.4  11.3  11.7   0.2
 11. AS???    10.200.6.199                                66.7%     3   10.9  10.9  10.9  10.9   0.0
 12. AS???    cc3-decix.ix.singtel.com (80.81.196.212)     0.0%     3  169.1 166.0 161.5 169.1   4.0
 13. AS7473   203.208.183.89                               0.0%     3  166.9 164.8 163.4 166.9   1.9
 14. AS4845 7473203.208.158.206                              0.0%     3  164.2 163.9 163.0 164.4   0.7
 15. AS7473   203.208.143.130                              0.0%     3  161.9 163.2 161.9 165.4   1.9
 16. AS3758   165.21.139.133                               0.0%     3  162.3 169.8 162.1 185.0  13.1
 17. AS3758   165.21.139.170                               0.0%     3  162.3 164.3 162.0 168.4   3.6
 18. AS3758   165.21.193.234                               0.0%     3  162.4 164.2 162.4 167.6   2.9
 19. AS???    ???                                         100.0     3    0.0   0.0   0.0   0.0   0.0
 20. AS9506   bb116-15-49-1.singnet.com.sg (116.15.49.1)   0.0%     3  167.0 166.3 164.9 167.0   1.2
Notice this germany route is the same one being shared to M1 customers and have the same issue.
M1 IPv4 result
M1 IPv6
Trace M1
Code:
  1. AS16276  141.94.18.1                                         0.0%     3    0.4   0.3   0.3   0.4   0.1
  2. AS???    192.168.143.254                                     0.0%     3    0.3   0.3   0.3   0.3   0.0
  3. AS???    10.69.168.62                                        0.0%     3    0.6   0.6   0.5   0.6   0.1
  4. AS???    10.69.162.162                                       0.0%     3    0.6   0.6   0.4   0.7   0.2
  5. AS???    10.69.128.82                                        0.0%     3    0.7   0.6   0.4   0.7   0.2
  6. AS???    10.17.151.118                                       0.0%     3    0.8   0.8   0.8   0.9   0.1
  7. AS???    10.73.1.36                                          0.0%     3    0.6   0.6   0.5   0.7   0.1
  8. AS???    10.95.33.8                                          0.0%     3    1.7   1.6   1.4   1.7   0.1
  9. AS16276  fra-fr5-sbb1-nc5.de.eu (213.186.32.213)             0.0%     3    9.5   9.5   9.2   9.7   0.3
 10. AS???    10.200.0.13                                        66.7%     3   11.0  11.0  11.0  11.0   0.0
 11. AS???    cc3-decix.ix.singtel.com (80.81.196.212)            0.0%     3  173.2 171.3 168.0 173.2   2.9
 12. AS7473   203.208.154.173                                     0.0%     3  172.9 171.3 167.9 173.2   3.0
 13. AS7473   203.208.183.130                                     0.0%     3  172.7 171.0 167.0 173.2   3.4
 14. AS7473   203.208.150.106                                     0.0%     3  241.2 239.3 235.5 241.2   3.3
 15. AS4773   220.246.65.202.unknown.m1.com.sg (202.65.246.220)   0.0%     3  243.2 241.6 238.7 243.2   2.5
 16. AS4773   182.246.65.202.unknown.m1.com.sg (202.65.246.182)  33.3%     3  243.0 241.6 240.1 243.0   2.1
 17. AS4773   1.0.245.49.unknown.m1.com.sg (49.245.0.1)           0.0%     3  243.7 242.6 240.5 243.7   1.8
ieatcable
Precisely. Never felt any bottleneck or slowness with local connections on 500Mbps. For me there is almost no situation in the house where everyone consumes concurrent 500Mbps 24/7. If let's say a 4K 60 streams at 25Mbps, I need 20 devices watching the same stream concurrently to exhaust the bandwidth on 500Mbps plan.
What I find is so many people are misled into thinking upgrading to 10Gbps will fix all lag when there are so many variables beyond local port speed like adapter/router speed and further upstream bandwidth issues. Salesmen are trained to convince you why <3Gbps is the reason you have lag.
Tested twice.
Impressive changes within 3-4 months. Seems they have made latency improvements to EU in general. M1 still mostly the same and now doing worse than Singtel if going by the number of reds.
M1 current results: https://www.meter.net/tools/world-ping-test/#0-149324-1e0bde
What I find with M1 is that, Europe is solid only if going through Arelion bi-directional. But often it is not the case, you will see destination bound go via Arelion, then source bound can either go by Vodafone (not so stable like arelion) or USA (higher ping which causes the reds in the test results). Sometimes don't even have Arelion path at all and ping goes above 300.
I suspect M1 will only have good ping if both M1 and the destination host purchases good IP transit to each other. Unlike VQ or Singtel now who advertise their IX routes in EU taking bi-directional connectivity into their own hands and does not depend on destination host having premium IP transit back to SG.
Time to take M1 out of the "better EU latency among the big 3 ISPs"?
IPv4 mtr result, from my main OpenWRT virtual router.
Bash:
                                                 My traceroute  [v0.95]
OpenWrt (42.60.14x.xxx) -> gra.lg.ovh.net (141.94.18.80)                                         2024-12-28T12:17:25+0800
Keys:  Help   Display mode   Restart statistics   Order of fields   quit
        Packets               Pings
 Host        Loss%   Snt   Last   Avg  Best  Wrst StDev
 1. bb42-60-143-254.singnet.com.sg                                            0.0%   110    1.6   1.5   1.0   4.9   0.5
 2. 165.21.193.22                                                             0.0%   110    3.6   4.0   2.0  31.9   5.1
 3. 165.21.193.21                                                             0.0%   110    1.9   3.8   1.4  56.6   6.4
 4. 165.21.138.245                                                            0.0%   110    2.1   2.8   1.4  26.4   3.5
 5. SN-SINQT1-BO403-ae1.singnet.com.sg                                        0.0%   110    2.2   1.8   1.3   2.2   0.2
 6. 203.208.177.213                                                           0.0%   110    2.3   3.2   1.9  25.5   4.1
 7. xn-lhrcl1-bo706.ix.singtel.com                                            0.0%   110    4.2   3.6   1.9  43.6   4.8
 8. 203.208.158.9                                                             0.0%   109    2.7   3.3   2.3  25.2   2.8
 9. 203.208.153.118                                                           0.0%   109  162.6 162.2 161.4 167.3   1.0
10. 203.208.178.221                                                           0.0%   109  167.9 162.5 161.5 189.7   3.1
11. 203.208.178.222                                                           0.0%   109  161.8 162.2 161.4 174.9   1.7
12. ldn-b3-link.ip.twelve99.net                                               0.0%   109  160.5 160.6 160.0 168.3   0.8
13. (waiting for reply)
14. (waiting for reply)
15. (waiting for reply)
16. lon-thw-sbb1-nc5.uk.eu                                                    0.0%   109  162.2 162.7 162.2 163.3   0.3
17. be103.gra-g1-nc5.fr.eu                                                    0.0%   109  163.7 178.6 163.0 316.2  33.9
18. (waiting for reply)
19. (waiting for reply)
20. (waiting for reply)
21. (waiting for reply)
22. (waiting for reply)
23. (waiting for reply)
24. (waiting for reply)
25. 141.94.18.80                                                              0.0%   109  165.8 165.4 165.1 165.8   0.2
IPv6 mtr result, from my main OpenWRT virtual router.
Bash:
OpenWrt (2400:d802:xxxx::xxxx:xxxx) -> gra.lg.ovh.net (2001:41d0:304:300::bb9)                      2024-12-28T12:20:42+0800
        Packets               Pings
 1. 2400:d801:4001:611::                                                      0.0%   107    1.3   1.4   1.1   2.3   0.2
 2. 2001:c20:3c00::6                                                          0.0%   107    2.4   4.0   1.6  32.7   5.4
 3. 2001:c20:3c00::7                                                          0.0%   107    1.7   4.7   1.3  48.7   8.7
 4. 2001:c20:0:3::35                                                          0.0%   107    2.2   5.6   1.4  39.9   7.3
 5. 2001:c20:0:3::a                                                           0.0%   107    1.9   1.9   1.5   2.8   0.2
 6. 2001:c10:80:2::a21                                                        0.9%   107    2.5   3.7   1.8  32.7   4.7
 7. 2001:c10:80:1::a129                                                       0.0%   107    2.5   3.3   2.1  19.6   2.2
 9. 2001:41d0:aaaa:100::9                                                     0.9%   107  187.5 181.0 171.8 191.0   5.2
10. 2001:41d0:aaaa:100::9                                                     0.9%   107  188.6 180.5 171.9 195.3   5.2
11. 2001:41d0:aaaa:100::8                                                    52.3%   107  167.5 167.1 166.6 167.6   0.2
12. be104.gra-g2-nc5.fr.eu                                                   47.7%   107  272.9 172.9 165.8 304.3  25.0
13. vl100.gra-d2-a75.fr.eu                                                    0.0%   107  166.0 165.8 165.2 166.3   0.2
14. 2001:41d0:0:50::5:11f                                                     0.0%   107  166.0 165.8 165.3 168.1   0.3
15. 2001:41d0:0:50::1:9d3b                                                    0.0%   107  165.3 165.1 164.7 165.6   0.2
16. 2001:41d0:0:1:3::ae33                                                     0.0%   107  164.9 165.0 164.6 165.4   0.2
17. 2001:41d0:0:1:3::a73d                                                     0.0%   107  165.0 165.3 164.8 165.7   0.2
18. 2001:41d0:0:1:3::aa44                                                     0.0%   107  165.1 165.2 164.9 165.6   0.2
20. 2001:41d0:304:300::bb9                                                    0.0%   106  165.8 165.6 165.2 166.1   0.2
Henry Ng
If you see your speedtest result you will know you are wrong. If you are on 1Gbps plan then no way you can get 2896 Mbps DL, the most is 300 Mbps only. I tested many times. If 1Gbps to US it can be just 30 to 300 Mbps only with ipv6.
You may want to read the post again and then check your reply. Or just stare the following picture for one minute and then check your reply.
If you still can not find the problem, make an appointment to check your eyesight. 🤣
