Is 10 gbps internet useless?
DragonFire
The main advantage if you have full 10g is better latency.
The native clock is far more granular than with 1g, which in turn means quite a bit lower latency.
The discussion gets quite a bit more technical, so I'm putting it in excessively simple terms. lol. Go google for more.
Hello_Kitty
higher speed can share with more family members in the same house without slowing down???
DragonFire
Do note that mgig (1/2.5/5g) will not negotiate 2.5 or 5g with a 1/10g switch.
If the mgig PHY supports 10g tho, it will negotiate 10g with the 1/10g switch. The vast majority of mgig equipped motherboards do not support 10G negotiation.
