perfectlight
- Nov 28, 2014
Whats the thing holding u back. I using china set. Can give u feedbackAnyone pulled the trigger? Still thinking whether to get the 1tb version.
hows the camera and daily battery?Whats the thing holding u back. I using china set. Can give u feedback
i bought the 1TB version as I wanted the 16GB RAM.Anyone pulled the trigger? Still thinking whether to get the 1tb version.
M5P used to be no 1 in term of battery life. So no doubt it will continue the trend. At the moment M7Lite is the best battery life based on DXOMark. So far no scoring for M7P yet.hows the camera and daily battery?
1TB is more expensive if compared to CN or MY. I also can't decide on it.Whats the thing holding u back. I using china set. Can give u feedback
most big department stores got live set for playing. RSR only exclusive to Woodlands Honor Store, but not sure when got demo set for playing.anywhere to go and try phone? want to compare
okay i go try later. I cannot tahan funtouch os, very cumbersome. also my magnetic powerbank doesn't work for my vivo x200 pro as the bottom part sticking out, very ugly.most big department stores got live set for playing. RSR only exclusive to Woodlands Honor Store, but not sure when got demo set for playing.
I don't use 3rd party powerbank, it is slow and not compatible. I'm using wired Huawei 50W and 66W powerbanks, it will give me the max charging speed same as the charger.okay i
Can fit a magsafe powerbank at the bottom for magic 7 pro?
ohh, cause i got a few magsafe accessories so wonder if can fit it.I don't use 3rd party powerbank, it is slow and not compatible. I'm using wired Huawei 50W and 66W powerbanks, it will give me the max charging speed same as the charger.
Have u bought?might be getting this too
You may want to bring it along and test it at the big department store.ohh, cause i got a few magsafe accessories so wonder if can fit it.
Both my Mediatek Dimensity 7350 and 9400 processors have far superior idle battery drain compared to my Snapdragon Gen 2 phone. Loaded power seems around the same to me. The idle battery drain is really that much better on Mediatek.i will choose honor cause i won't pay more than 1k for mediatek processor. then i feel mediatek processor consume more power than snapdragon.
7350 is 4nm. And the battery is much better than the SD 8 Gen 2 which is also 4nm. Both 7350 and 9400 exhibit remarkable standby idle batrery drain.sd 8 gen 2 is 4nm
9400 is 3nm
need to compare with sd 8 elite 3nm
smaller size means more energy efficiency.
https://www.gsmarena.com/battery-test-v2.php3
