OnePlus 13 series
KeYoKe
Yeah I vaguely remember it's both. There is another major manufacturer TCL (should be hua xing) in China.
OP13 and 13R both using BOE right?
Which display mode you all using?
Think china got a few screen manufacturers, the more common ones:
BOE (京东方)
VISIONOX (維信诺)
TCL (华星)
Tianma (天马)
lawreo2002
Any kind bro can recommend a tempered glass option for OP13 ? Heard about the ultrasonic fingerprint sensor not working well with all screen protectors. Thank you
kashix
Iirc mixed between both :s13:
You're right sia, I thought only Tianma, I maybe win panel lottery
I using the default, color temp also default
Ya TCL
Op13 and 13r is BOE. 13 for sure is BOE, 13r initially no idea, then saw on OnePlus website using X2 material, then i know is BOE
Am using vivid
haha long term user but casual techie level at best, nv go that deep into things like haptics etc nor able to compare it to iphones etc. Prob some or alot of users here are more familiar with functionality or where things are located even
@tkte_85 bro what display mode you using also?
KeYoKe
Check out smart devil on taobao
闪魔
Can consider this brand, uv film, used before for op12, not bad
【淘宝】大促价保 https://e.tb.cn/h.TPVhEwnFUuvPIoB?tk=MIwmeWecQVW MF287 「摩双适用一加13手机膜AR菲林膜1+13uv全胶OPPO ACE2uv光固膜10Pro保护膜12水凝膜11全包13钢化膜ace3Pro贴纸5」
点击链接直接打开 或者 淘宝搜索直接打开
lawreo2002
Thanks guy. Been using smart devil for a few iPhone models. Good brand. Checked the OP13 one. They only have the soft one. No tempered glass option.
KeYoKe
For those that interested in the Oneplus aramid carbon fiber case, 50 units will come in next week. Price will be at 39...
Think quite limited edition as whole of taobao cant find. Those whom want to grab it, while stocks last! Only 1 batch coming in.
MangoCAT
Got my 100W PB cigarette box - Nubbad. i fully charged it for ard 20 to 35min from 60/67% factory charged. @s-ghost can cry in toliet longer le
MangoCAT
Wow so u got the powerbank in the end. Who the kind soul let u tag on the order?
oppo de shopee store. 100 less 12 and got few bucks of coins so end up getting it quite cheaply at 68.41. with some muji small items
