Honor Magic 7 Series
ltrinityl
Anyone knows how to disable the "Power Intensive App" notifications?
Kinda irritating
w3nj13
Anyone knows where to find M7P physical cases to try out? Even jb? I wanna to feel the cases, not through online
Innocuous*
I have a SG Honor Magic V3.
I plan to buy a China Honor Magic 7 as SG dealer does not bring in this variant. I prefer this variant as it is slimmer, lighter and the specs are good enough for me.
May I know whether can I use the same charger from my V3 for China Magic 7? Or do I have to use the charger that comes with China Magic 7 together with a travel adapter?
Encrypted11
Do you have any issues with any apps on MagicOS 9? Cause I have banking apps and just concerned if it will work well along Singpass and all? Google Wallet can be used for transport? Need to wake screen? Your advise will be most appreciated. Cheers Bro.
Been using Magic OS 9 since Nov 2024 on Magic 6 china ver bought (since mar) for China trips/China domestic apps.
By the third Magic OS 9 build or so I haven't had usage issues or weirdness. China ROM OS ads can disable by disabling the settings one by one.
Cell signal quality is superb. Banking apps and Singpass work but Google Wallet has limitations, cards will add to wallet and your payment autofills but contactless is unsupported (possibly due to non-pro model's less secure 2d facial unlock). Idk about global ROM situation.
yhw22
Just use your existing V3 charger but note that your charging max is 66W. I will suggest you to use Magic 7 charger which is 100W.
eatens
Anyone here got the Honor Watch 5 and used with Healthy 365? Thinking of jumping ecosystem entirely
originalShrimp
Hihi, would appreciate your feedback since u are using the china rom one. I been contemplating to get the china variant with 1tb set. But my concern is that banks, and other apps might have issues using it. Also, with regards to contactless as I have been relying on contactless payment using my S23U. Was wondering if there's any issues with it.
sobered
Wonder if there's an ai studio similar to oppo or iPhone where you can generate cartoon pics
