Not too bad, I haven't do a full 100 to 0 test,but can get me 1.5 days of moderate usage. Perhaps 9h SOT?How's the battery life of this phone? Whats the screen on time u all achieve?
https://sg.shp.ee/gM651nT Most of my phones are using xundd casing. Good and durable.Anyone knows where to find M7P physical cases to try out? Even jb? I wanna to feel the cases, not through online
I get around 10hours to 10.5hours sot. It's pretty good, guess oneplus 13 should be the same.How's the battery life of this phone? Whats the screen on time u all achieve?
bumps bumps.. anyone knows?Anyone knows how to disable the "Power Intensive App" notifications?
Kinda irritating
Do you have any issues with any apps on MagicOS 9? Cause I have banking apps and just concerned if it will work well along Singpass and all? Google Wallet can be used for transport? Need to wake screen? Your advise will be most appreciated. Cheers Bro.
Just use your existing V3 charger but note that your charging max is 66W. I will suggest you to use Magic 7 charger which is 100W.I have a SG Honor Magic V3.
I plan to buy a China Honor Magic 7 as SG dealer does not bring in this variant. I prefer this variant as it is slimmer, lighter and the specs are good enough for me.
May I know whether can I use the same charger from my V3 for China Magic 7? Or do I have to use the charger that comes with China Magic 7 together with a travel adapter?
Oh don't see that but think you can go settings to change notificationsbumps bumps.. anyone knows?
You can't use it on Healthy 365. No option for 365 to connect to Honor Health.Anyone here got the Honor Watch 5 and used with Healthy 365? Thinking of jumping ecosystem entirely
I also bought the 1TB. shopee show the delivery is pick up. deliver tomorrow.
replying to the above ^
Meaning cannot download healthy 365 app?You can't use it on Healthy 365. No option for 365 to connect to Honor Health.
think he means can download the app, but the watch data (e.g., steps) won't be able to sync between honor watch and 365Meaning cannot download healthy 365 app?
Watch not compatible with healthy 365think he means can download the app, but the watch data (e.g., steps) won't be able to sync between honor watch and 365
