Genshin Impact
rrr2015
how to select more stratagems? seeing all stratagems on the left but no means to add. using controller.
Blindaim
Some strategems are fixed and must be used. Most strategems need empty slots that are only unlocked in later stages.
rrr2015
it keeps prompting that i can add more strategems but i see no way of adding. fixed ones are always there.
Blindaim
Need to remove existing strategems then can add. If cannot remove, then is fixed for this stage. Think the prompt is just telling you, got new strategems to choose instead using the same strategems.
Roughice
Is it better to get C4 xiangling or C1 xingqiu? Asking because of the current lantern rites event
Blindaim
C4 Xiangling. Quite impt. 40% duration means extra 4 seconds of pyronado and 4 secs less downtime.
C1 doesn't do much for Xingqiu.
evildoer
i think c4 xiangling better. the extension of the burst seem more important than additional xing qiu rain sword
rrr2015
just an alternative opinion. XL quite unless outside abyss. so if abyss not your priority, getting XQ c1 so your XQ just one step away from XQ c2 which reduce hydro res. both can be bought from shop.
treeskull
It depends which DPS u use the most. XQ is good for normal atk, and XL is good for offield DPS. U have to see which of their cons benefit the most for your team comps and select accordingly
evildoer
i c2 arlecchino yesterday .. lol
still cannot 36 stars in floor 12- room3
