Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    202
gapboy
Omg means whatsapp die die must use google drive? Coz my laptop down …
cant use this method?
your phone dont have google drive app?
https://www.google.com/url?sa=t&sou...ma4LegQIMxAC&usg=AOvVaw3RUXIMNV6UX0hQIq-yVkng
KeYoKe
Actually really depends on how you use the phone and with which case. My older dbrand case for S23 Ultra also similar design and I've had absolutely 0 scratches/discoloration on my phone. I think if the back part has a bigger cutout or a wide open cutout, then your risk of scratching the lens around it is much higher. There is a reason why I keep using back dbrand is because it's done a very good job of protecting my phone and it lasted 2 years without even disintegrating or any sort like that. But its a boring case if you have a nice phone color since the grip case is black and only in that color.
No bro. The camera design of s23 ultra is different from s25 ultra. Is not susceptible to paint chip unlike the camera design of s25 ultra.
Not sure why they change to this ugly design this year and worst thing it is black color... The color coating Samsung uses isn't good. Just a search online about Samsung paint chip will yield tons of results.
I don't mean dbrand grip isn't good bro. Dont misunderstand. But to paste camera protector or not just purely based on personal preference, for me i will paste it as i like my device to be pristine
elmariachi
Maybe it might be worse with the S25 Ultra then but my camera rings seems well protected with this case so I'll just use it and see how it holds up. I generally do not keep other stuff in my pocket with my phone also so hopefully it'll be okay for me. Confirm if put lens protector have to deal with other issues related to image quality so I'll have to depend on this case to protect my virgin.
KeYoKe
I have been wanted to try dbrand grip for quite some time. But the case is exp af though :s13:
elmariachi
Yeah its expensive but very durable and doesn't really increase the size of the phone. My longest lasting case I've used. No regrets.
