reddevil0728
- Dec 16, 2005
Not necessary to have 512gb alsoHaha.. for web surfing and general use, who needs 1tb? And this is a desktop mac. Can always plus external ssd to it.
whats the minimum u suggest? 2 tb?
hmmm why is it about affordability? should be about use case also no?The biggest amount one can afford to buy. I'm using MacBook Pro M1 Pro since 2021. 1TB internal storage. Wish to get the 2TB. Too ridiculous pricing.
Must have at least 50% of free space as buffer.
Files I work with are huge. Photos.
Once work done, I moved work files to NAS.
You might be able to afford, but then you might not even use close to 10% of it. then a bit pointless right?
yep. hence is not so much about affordability right?It is up to the individual to know what they need.
The cheap PCI-E ones aren't compatible with mac mini I suppose? Unless you get an additional PCI-E to thunderbolt kind of enclosure (not sure if those exist)So many affordable 10gbps adapters online.
https://shopee.sg/search?keyword=10gb ethernet adapter&is_from_login=true
Can I ask why external storage is not an option? There are external SSDs that should be quick enough for things like photo editing right? Seems to make more sense from a cost perspectiveThe biggest amount one can afford to buy. I'm using MacBook Pro M1 Pro since 2021. 1TB internal storage. Wish to get the 2TB. Too ridiculous pricing.
Just to clarify, this characterisation is based on your preference right? Not in general?256GB is nonsense.
512GB is barely scraping.
1TB is good starting point.
2TB is very comfortable.
4TB and 8TB is overkill, unless one works with terabytes of raw video files.
cause I don’t see how 256gb is nonsense if someone just uses the Mac to surf the net and nothing else.
Hmmm.in my experience, it applies to both general and my personal preference.
Hmmm.
but again back to the scenario I have been talking about.
why is 256gb nonsense someone who just surfs the net and wouldn’t even have much if any things on their Mac?
Ya, I think it’s important for people to be aware that there are a lot of use cases than their own to suggest it’s nonsense to get something that’s not within their use case.yeah. Makes no sense at all.
For someone who takes a lot photos/videos with their iPhone and edit with the native Photo app, 256GB is more than enough to last them couple years before upgrade.
If it is just net surfing, i wouldn't even buy a mac. An iPad will be more than sufficient. Even a cheap $200+ android tablet will be ok. I use a mac because i want to be able to do real work and multimedia edit while enjoying the Apple ecosystem.Hmmm.
I find this hilarious.yeah. Makes no sense at all.
Hmmm.
I have a ipadpro and i wont use it for web surfing, only play games or video editing. The browsers operate in mobile mode, some website like google sheets or notion just cannot make it.If it is just net surfing, i wouldn't even buy a mac. An iPad will be more than sufficient. Even a cheap $200+ android tablet will be ok. I use a mac because i want to be able to do real work and multimedia edit while enjoying the Apple ecosystem.
A mac mini is still convenient to use external storage as it is a desktop, but for those on macbooks and always on the go, carrying an external storage can be tedious.
The thing is to go into credit card debt for something they rarely or dun use at all. Nowadays so easy to spend and spend with credits or bnpl. Haha.Ya, I think it’s important for people to be aware that there are a lot of use cases than their own to suggest it’s nonsense to get something that’s not within their use case.
