andyqkw
just my experience. in bedok reservoir/tampines area, coverage has improved (more bars) but speed still the same as 1 year ago.
not a problem for me as i dun have speed sensitive apps/needs on mobile.
Used to get around 70 Mbps ++ at Bedok MRT and now only getting 34 Mbps and Eunos MRT only getting 2.5 Mbps in recent speedtest.
loganrunning
the 20 to 30+ is what i have been getting for a while. Even out in the open at middle road/bencoolen junction. maybe it was late afternoon. Ironically, this was the same speed at kaki bukit mrt exit, next to Simba HQ 🤷‍♂️
1.5 to 2.5 is at the known spot near my place, but that is probably one of the "blind spots"
andyqkw
Used to be much faster and now playing a low-resolution YouTube or Tic Tok/抖音 and it will keeps loading/buffering non-stop during the peak hours...
Likely due to more people signing up with SIMBA and the bandwidth is too congested to handle the traffic.
loganrunning
yeah, most likely, given some recent published reports.
Food_Lover
Yes. I realized this too.
Jurong640
@Habrosus
@Jurong640
Simba really jialat. I tried for one week, give up.
Cannot get stable connection.
at times the router just fail to connect.
Never get sufficient bandwidth for Disney+
going to update in app to cancel the plan :(
ok noted. It doesn't work for you then, in your area.
If you want fast, for router, for 200GB, then can try Zym. I have been using for more than half a year
duabuiji
quick check, these days do u guys keep getting the message saying ur sim card sent a message? happens to mine and my wife's simba line
Habrosus
Anyone encountering Emergency Calls only? Any way to troubleshoot this issue?
Are you trying to call out or someone's trying to call you?
My Simba SOP: (iPhone)
- Delete default and set all APN to TPG, then restart phone.
- Restart both phones, if possible.
