Poco X7 Series
farmers
Hey guys, im looking to buy a screen protector and case for the poco x7 pro from shopee/lazada.
any recommendations? was looking around and most of the variant shows as "poco x7 pro 5g" is it the same as "poco x7 pro"?
Thank you!
1c3_5n0w
Thank you!
Yes, they are interchangeable. But X7 and X7 Pro are not.
I highly recommend the SmartDevil brand for ~$8 for a two pack on Shopee. I know that on Shopee, there are a ton of cheap protectors, but SmartDevil has a good oleophobic coating, which contributes to a really good experience AND a guide frame to ensure you get a good alignment and install on your first try.
Purely anecdotal, but I also notice that SmartDevil chips less easily at the sides compared to cheap protectors. Could be a placebo, or could be because they have 2.5D edges.
A two pack is likely sufficient to last you the entire duration of your phone ownership, without major accidents, in my opinion.
I would advise against buying the blue-light filter option and just buying the standard clear version.
My only gripe is that there is a front camera cutout, and dust gets stuck in there and is really hard to remove. Subjective matter of preference though.
Case wise, I personally cheap out and get whatever I like. But many here like XUNDD cases. Pertaining to the X7 Pro specifically, I think the Nillkin Frosted Shield Pro looks pretty sexy. You can expect to pay about $8-$10 for each of these cases.
Hope this helps!
oddbasket
App Vault has a new update which opens it every time I open app drawer, bloody annoying having to tap a few more times to go to app drawer. At first I uninstalled app drawer updates and went back to normal, but it got auto updated again along with the security patch. :mad:
Turns out if you go to the setting icon in the app drawer can disable opening the app vault search under:
"Open search after opening App drawer" (y)
froztheart
Ah yes, this "App Vault" is annoying af.
