Honor Magic 7 Series
shager
How abt vivo
Vivo X200 Pro is a great phone. It's absence in Singapore is sad as it means we're actually going to pay near S25U prices for the 512gb global rom version of the phone from Malaysia at S$1425.
The Honor 1tb is around $1333 if you wait for the Shopee 3.3 / 4.4 sales. Same with Oneplus and Oppo at Shopee. Prices are around 11xx and 12xx respectively, maybe cheaper.
yhw22
Yes, both from Honor original.
sorry for the late reply. i tested using honor provided 100W charger, cable and freebies wireless 100W charger, I got no problem getting 80W by default. nothing was done, you may want to unplug your cable again or re-place your phone again to the wireless charger.
yhw22
Notice under Settings of Camera app, got a new feature, "Lens cleaning reminder". Not sure when this feature was implemented.
unclepp
Got it. It was the cable. It works now, showing Max 80W. Thanks.
tweeety
so far i think i haven use that yet, any tempered glass i can buyn use which i is high quality?
the one i buy is shiat , giving finger print scanner issue, then got a circle cutout thing on the fingerprint side,
and the corner are block by the glass black stuff, my screen look smaller than before
oh ya the charging speed also insane, my sammy from 70% to 100% also need 45 mins charge , this one 10 mins like that full liao
I’m also using s23u, thinking of changing to magic 7 pro, what do you think of the camera photo quality ?
sobered
s23 ultra quality about the same as magic 7 pro. s25 ultra should be the same as s23 ultra actually. vivo x200 one really different
fool1988
I'm deciding between the S25 Ultra, Vivo X200 Pro, Honor Magic 7 Pro, and Oppo Find N5. Any thoughts?
My main priority is long battery life since I prefer not to carry a power bank. A good camera is also important, especially for portraits (to capture my kids growing up) and some landscape photography.
Additionally, I’d like a phone with a stable and well-optimized UI, minimal ads, and minimal interruptions for my work profile.
anthonygreenisreal
OnePlus 13
cloh2023
Help needed: I have a eero max 7 mesh system and the RSR.
My RSR only connect to the wifi band 5ghz and not 6ghz.
How to connect RSR to the band 6? I cant find any settings on the router that allows me to manually do it
stressmage
If your rsr is china rom then cannot. China no 6ghz for wifi.
ltrinityl
When is the next patch coming for local sets? Saw the next patch has tap twice to lock screen feature
