Oppo Find N5
fool1988
Time to talk accessories.
This foldable looks to be something I’ll keep for awhile, is tempered glass for the outset screen required? Inside screen I’ll use the default
Taobao seems to have lot of cases with built-in outset tempered glass. Since the N5 doesn’t use an under-screen fingerprint scanner, I guess it should be fine, right?
fool1988
Yes... not same as Samsung's Secure Folder......you have to try it to know how it works...
But if the goal is just to separate apps into different spaces or hide certain "apps," I think both options should do the job, just with different approaches. Secure Folder has its quirks too—like, no matter how well you hide the apps, they still show up in the battery monitor. If your wife’s tech-savvy, you’re busted! 😆
However, I will miss those special features that only available on Samsung Phone, such as Samsung Pay, Samsung Keyboard, Goodlock, SecureFolder etc.
fool1988
Anyone order any case from Taobao / Shopee, can share the link? Mine XUNDD seller told me that they will need time to ensure the case is completely fit the Oppo Find N5 before they can send out for delivery, which approximately late for 2 weeks...very sianz
artncraft
You can try it out at the Oppo shop, Harvey Norman, or Challenger. Maybe it’s just me, maybe due to I just woke up this morning, and my eyes are still a bit blurry... haha!
I checked the sensors size and they are quite small.
Likely all the photos undergo serious enhancements by AI e.g. brightening, sharpening and saturation.
Yuripa
When you guys said camera cannot make it, as in all the camera or just the UW?
Depends on which phone are you comparing it with.
If compare with z fold 6, overall it's slightly better only.
Justbear
【淘宝】假一赔四 https://e.tb.cn/h.THYogLEzgKima09?tk=sCtye8nBYyY CZ005 「轻奢羊巴皮】适用oppofindn5手机壳findn5新款折叠屏保护套铰链全包OPPO Find N5超薄防摔商务n5的支架外壳男」
点击链接直接打开 或者 淘宝搜索直接打开
Bought this. Likely can't reach before Monday.
RaebRalop
This was my consideration as well. In the end I decided to try and go for full immersion.
But hor , $1849 + $449 = $2298
I assume yours is via paynow for max discount so $2099 + $299 = $2398
Ok la....save the hassle plus 3 free gift for $100
fool1988
Looks good, but I’m worried my oily hands will leave smudges on the back case. I’d prefer something that’s easy to wipe clean.
fool1988
Yeah, that why I said it look wasn't that sharp, more like AI processing or look more blur like that..
1982-1994
As usual, I'd use it naked should I decided to use the phone
This time round, in white
Current foldable is in black
