Xiaomi vacuum robot users lip lai please
tellim
Xiaomi G20 lite can suck dry rice grains on the floor?
My cheap simplus cordless broken down on 7th mth usage, warranty replacement also died after 5 mths just nice one year warranty over.
I don't need cordless to last but I dun want to claim repair or replacement in less than a year.
phiber
Anyone has Mova robots from China? Does the app work outside china? Their z50 ultra looks good but it's double the price locally at $1.7k!
The roller mop design seems quite good..
phiber
i got Narwal J4 as a gift from china. I manage to fix the geolock, able to add it to the App. If anyone is interested to know, just PM me
Narwal J4 is the latest version. Narwal Freo = J3 in china
Now all the new narwal are geolock? I have the j1 in china app and works well .. thinking of the 001 Max or J5X
crandfs
How you do wan?
VEF888
anyone had similar issues, just changed worn out xiaomi wheels, but the new wheels are actually too high, as the result , the main brush can't touch the floor?
wheels still can move freely but protruding parts are quite thick.
bought the wheels off shopee for quick delivery, but seems like all the wheels in taobao are quite thick was well.
Mark8888
Hi guys, I know it is 2025 but I am still using gen 1 Xiaomi robot vacuum. I had recently changed my home BB router and facing some issue. The robot is offline and I tried reset (both router and robot) and reconnect using 2.4Ghz but to no avail.
Any other suggestions?
go to the Xiaomi Home App under Profile under Additional setting change the region to China Mainland.
Ludwig
Set to China Mainland since day 1 of usage. But only recently unable to connect after changing router. Had created a separate network of 2.4Ghz also to no avail. Able to connect on mobile hotspot.
jaykill_92
Robot arm not as useful to me, but I saw a damn good price of $1150 on the bew Roborock Saros 10R (after $180 Shopee voucher) before lunch earlier...limited flash sale
SandMan
alright have used the tricut roller for several rounds. yes prevents tangles on main brush, with only 1 strand coiled on it. However, some hair got coiled round an end spindle and it seems like suction power is slightly reduced.
crandfs
The narwhal is the best lah, still completely hair free main roller as well as side brushes.
Eruditeswine
I'm using the tricut brush with a tricut brush cover. Zero hair on either end. Perhaps give it a try.
On Reddit,
In case adblocking: r/RobotVacuums/comments/1fzubob/brush_covers_for_the_tricut_brush_that_prevent/
Tmall URL: https://detail.tmall.com/item.htm?id=836563418245
Good luck!
SandMan
On Reddit,
Good luck!
Thanks for sharing. Yup I bought this cover together and installed it with the tricut. Hopefully hair round spindle end wont be a regular occurrence.
crandfs
Narwhal come out with version 002 using rolling mop wor! Rolling mop uses clean water and cleaned mop surface to clean the unmopped floor, then squeezes clean and rinses the dirty mop surface before using it to clean another unmopped floor area
