Oppo Find N5
disr87
Actually what the pen can do? I no bother to open the pen and use, unless there is a phone case that can "keep" the pen, otherwise I rather to use iPad and Apple pencil if I require to write or sign on something which is not very often.
Tbh not much la. Just depends on your use case
Justbear
For the pen when It arrives next week due to being singtel set, I prob just gonna keep it sealed and sell along when I move on. I rmb the time when buying Huawei mate 20x and it comes with pen also but end up I totally dun use it at all after opening up e box
Can use finger nail to write without pen as well right?
RaebRalop
For me just when editing video and picture on the move....just to get the precise number. A bit ocd...
diablos18
Telco set at 1849 or oppo set at 2199?
Screen protection plan : Oppo wins
Additional 12gb ram: Oppo wins
Are there any reasons why I should take telco set for the 350 difference?
tkte_85
Huh there is no additional 12gb ram, it's all virtual using the internal storage
Amuroraysg
where got so special Oppo ownself upgrade ram? all same except for no magnetic case and charger/powerbank.. and 1 year screen care.
hstreamy
Buy outside cheaper than Oppo store....can go as low as 2000 now.
artncraft
Yes, it will be useful in annotation.
However, there is no placeholder on the phone.
I have to check around for a case that holds the stylus later.
artncraft
I got the $200 voucher in Shopee that can reduce the price to $1999 two days ago.
However, I did not go ahead as the overall quantum was a bit high on account of poorer cameras and a weaker processor, and I don't foresee much use for the added package.
The SingTel price of $1849 and the stylus are just nice for me.
siaoz85
I have both the Honor Magic v3 and Find N5. Seems like a lot of things that matter to me is much better on the Magic V3.
V3 provides a FRONT and back case but N5 provides only a back case.
V3 can support PD fast charging at higher watts but N5 can't. Have to lug around the extra oppo charger and cable.
V3 can wireless charge fast on a 15W wireless charger but N5 is super slow unless using the 50W wireless charger. Again have to lug proprietary tech.
V3 vibration is much stronger than N5
Sound is better on the V3 than the N5
Share your pros and cons with me!
dgeralds
Is there PRIVATE SPACE in the phone? Can anybody confirm? Not 'private SAFE'. Thank you.
Barbarblacksheep
How slow is the slow charge via PD? Is it "normal" charging or fast charging instead of ultra fast charging when compared to a Samsung?
Overall which would you choose if it's Magic V3 vs Find N5? I care abt camera, battery life and software.
artncraft
I just ordered a folding case with spine protection from Lazada.
The spine and the screen should be the weakest link.
There is another case with a stylus holder, but it looks bulky.
Justbear
Just tested the sound. Yes V3 sound more clear, but N5 loudness would edge V3 out by abit.
Taking Ed Sheeran "Perfect" for example. At volume 7, V3 can hear the train but N5 can't.
Amuroraysg
finally finish setting up stuff.. last thing got me fiddling the longer is wallpaper...
can't get any good one that work for both screen last resort download it and manually add it using wallpaper setting.. instead of let the wallpaper app do it..
