jogging and motivation thread
WussRedXLi
Wah, Take care of that wound. coz the last time took me about 2 weeks of changing dressing to soak up the oozing liquid (plasma?). This period of oozing is critical as to not get it infected
Yep no worries, last time got experience with the knee liao, that one terok. All these moving joints wounds take very long to heal if the wound is deep/big enough coz repeated movement....heh.
WussRedXLi
Really is pregnant :oops:
https://www.triathlete.com/culture/news/is-it-safe-to-race-while-pregnant/
Shortly after taking third at T100 Miami, Holly Lawrence revealed she was pregnant during the race. We asked an OB-GYN what all triathletes should know about training and racing while pregnant—and what to expect post pregnancy.​
sph777
Sigh....buanged on Jubilee bridge. Luckily was not training on the roads.
Was off saddle and full power gunning up the slope of the bridge in tallest gear and ultra low cadence doing the 8 reps strength training drill and then the LHS crank came off. Heng was strength training and not high speed sprinting. Buanged at around 12kmh.
Caught a flesh wound that split open on my left elbow, took 30 mins to stop the bleed.
Also knocked my head on the floor, helmet got a small dent, sigh.
Really gotta tighten (nearly over torque) the hex screws securing the crank liao. And once every 2 weeks check the screws and crank. ******* dangerous, even got chance of serious injury/death.
This part, the red one + the pedals. Think both a factor of not tightening enough and also off saddle repeated swaying outwards ba. After a period of time just came off esp exercerbated during very high torque with side shear scenario.
I guess the lucky thing is that it could have ended up much much worse, hospitalized etc.
Yes could have been worse, nonetheless recover well!
sales69
Ya those wounds at knee, elbows... Pita when bathing/change clothing.
Take care man. 💪
Ender
Take care man. 💪
Maybe too late for your current injury. I find this is useful. For my first injury, the hospital uses those expensive 3M transparent dressing that is able to withstand shower. But they are expensive. So I hunted in shopee for China alternative and founds these. They perform as good as the 3M. but you need some skills to apply. And they are cheap enough to make multiple mistakes. Also you can use your own padding with the china tranparent dressing. I use Bactigras and gauze to soak up the oozing liquid. The china one abit troblesome, need a pen knife to cut line so you can peel off the non adhesive layer from both side after applying. Need to cut the right depth. But practice makes perfect and they are so much cheaper than 3M.
Below is a random seller I anyhow search for. there may be cheaper seller out there.
https://shopee.sg/5M-Waterproof-Med...1e&xptdk=3022e217-e5f6-4975-b59e-8237c3413d1e
sales69
Thanks for sharing. 👍
Kind of similar to those used in hospital. Touch wood, no chance to use again. 😄
Ender
The problem is my right knee 🤔
After my right achilles, then my knee not really good liao.
The flexibility on my right leg not good and the knee area feeling a twisting sensation when walking or jogging and it's ache suddenly 🤔
That's the issue with running high load with current injury not fix yet. When you run with injury, your other part of the body takes more load as you try to adjust and lighten the load of your injured Archille's. Prolong period the other part of the leg with get injured.
Not to say cannot run with injury, in fact I believe running with injury will heal it faster, just that you can't run with the same training load, need to regress your distance, pace, duration and if possible run on stadium track.
WussRedXLi
OIC, can try next time ba....for bigger wounds. It shd be useful. Coz the normal gauze if stick then gone case already. So usually prefer to leave it opened, usually i'd wash it often (soap and water) to prevent infection.
WussRedXLi
Oh, then dont run first for the next 1 month then slowly progress up. Do other things like very light stationery cycling or brisk walking.
You wanna try strengthening first? Just the hamstrings, anterior tibialis, calves and then glutes. 10 mins alternate days can do already. Dont have to gun till failure, as long as you can feel mild discomfort ok already, is already very useful.
Why dont pick up racewalking also. From my previous experience, it is really good to boost cardio and generally as good as running but without the impact / injuries. (still can get injured if anyhow, like if you anyhow raise the distance without following 5-10% rule)
BTW it is racewalking, not brisk walking. Racewalking you can progress till 4-5 min/km during intervals/"sprints".
My racewalking sprint i trained until around 4:10 min/km, i can tell you it is a crazy fast twitch stimulus. Can really preserve any remaining type II fast twitch / motor units.
WussRedXLi
Going to buy the transparent medical tape with my next $3 shopee voucher. heh...... sure will come, i have 3 accounts.
BTW, one more thing, i feel that runners and esp cyclists really need to get that booster Dtap/Tdap shot. I think $70. Then if got falls, this is one thing off your mind liao. I have already gotten that after my first major fall.
Esp for those runners on Rail Corridor, the risk is inherently higher for that location vs concrete jungle like MBS area.
Jeremy1
That's why I wanted to try lesser cushion shoes, think maybe will be better for me for rotation.
I still can jogged but as what you said definitely not so fast and also my right leg tends to get tired faster.
Jeremy1
Now I am super concerned on my right leg.
WussRedXLi
See polyclinic and do x-ray, slowly rule out. You have so much time, can go through this (slow) route. Coz of your age can also request for physio. Then you will know the proper specific strengthening exercises to do and focus on.
But after that for sure the general ones all must do. Basically everything involving the legs, and followed by core (just do things like push ups ba...non specific and slower but it has many other benefits so 2 in 1)
