Citibank Maxigain interest calculation?
jericho75
Dunno got tio chopped boh?
That time I have about 70k plus in a maxigain account which I've opened in year 2019. That time was earning ok interest every month.
Then covid came and maxi gain dropped rates until like non existence interest. I removed a chunk of money and put in RHB 4.1% interest and maxi gain account just keep 15k inside so dun kenna monthly charges.
Until now my account should be under max counter of 3%. Then saw end oct, nov, dec, jan I got earn like $37 interest for about 15k inside.
Then I began topping up this maxigain account from jan - feb 25 with about 44k on and off weekly inside this maxi gain. Never withdrawn money out. Now this account has about $59500 inside.
Then how come end feb 25 interest is only $38?
I called citibank and was told the interest is based on lowest balance in jan and lowest balance in feb calculate. Then I asked issit end march then can see some significant increase in interest the customer service says yes.
How true is this? I felt like tio pian liao. Might as well dump inside fixed deposit.
jericho75
If i am right, you topped up on 2nd Feb onwards instead of 1st Feb ?
Take a look at the T&Cs, looks about right.
yes. top up on 2nd feb onwards
but jan opening is SGD 15,123.03
Then top up money sometime in end Jan 25.
feb opening is SGD 21,160.49
Then if based on SGD 21,160.49 for feb interest. How come amount is still $38?
21160 x 3% = 634 / 12 = $52?
DenOOO
Because they take the lowest end of day balance in Jan.
DenOOO
So Feb interest is take Jan balance give?
The Bonus Interest is computed at the end of each month based on the preceding month's lowest balance, and number of days in the preceding month, and paid on the last day of the month.
From what i see, yes.
jericho75
So like that means April then can see interest rates hike?
jericho75
which means on 1st Feb, you have your lowest balance already which is around 15123.03 or abit more due to interest.
No Jan opening about 15k
Then 28 Jan top up until 21k.
Means Feb opening is 21k liao
Imhthc
meaning you will see a delay effect in the bonus payout on cases when you do not even make any withdrawal and have top up for the month like your case.
What about If I keep the full sum till end of the preceding month and make withdrawal at the start of this month, will I still get the bonus interest this month?
Pyroxene
If you withdraw just the interest quantum, yes. If you withdraw more than that, then no.
Hot2002
just received citi email, step-up to 3.01% for the first 100k by the 12th month. looks good ?
i don't have a maxigain account yet but i have maxisave & step-up account now. i have to maintain a minimum of 15k across maxisave and step-up account to avoid a service fee. thinking to open maxigain account now and transfer 1k monthly from maxisave/step-up. still maintaining a minimum of 15k across all the 3 account. finally pump up maxigain to 100k at the 12th month
don't know if citi will terminate the promotion at the 12th month ........... ha ha
JuniorLion
12th month is Sep 2025.
Every other banks cut interest already.
Matter of time before citibank cuts.
ahnyaahnya
It says so in their T&C
jericho75
They will set the interest as high as they need to get people to put money with them. No point leaving money on the table.
Citi dun really have alot of customers so they might still be able to pay interest
