Oppo Find N5
way_landr
Has anyone tried the magnetic case with the freebie portable?
The charging speed is super slow and the portable gets hot, is it me doing it wrongly?
fool1988
Encounter this issues when I use cover screen preview to take like 5-6 photos yesterday with my kids at jewel...Aircon environment and the phone not very hot just a bit warm...wth?
Chevalier
Odd. I was at the park yesterday, sun blasting the us and the phone got warm but i didn’t get that warning man.
KeoNxaGa
Oppo Find N5 fold isnt working with Android Auto at all. Vehicle couldn't detect the phone when connected via cable to it. Only can charge phone..
Any idea why? Anyone having same issue?
Google said need phone to be running on Android Pie Ver9. But our phone is colourOS. Is this the reason why it couldn't detect?
Also, it's not possible to install android auto into N5 as it's build into systems directly.
Bro, ColorOs is only the skin on top of Android. I believe N5 is Android 15(Vanilla Ice Cream) which is 6 versions after Android 9(PIE) .
Did you use the default cable that came with the N5? Try it.
GlueStik
I keep getting overheating error despite the phone is warm or lukewarm or hot. Happens anytime charging or not charging. So much so that it restrict my game my charging and taking photos. 1st time using oppo. Already turn off all the fancy stuff that might cause heat but still phone shows hot warning all the time.
Have 2 set, one with 70% overheat message. One with 25% overheat message. No background running. Any solution for u? My last Samsung I throw a ton of stuff open also never had a single overheat warning before.
1982-1994
Weird I have no such problem at all
My usages, browsing, music, streaming video, telegram
enimen
Try liao... Still nothing. It's like the car unable to detect the AA.. but yet I could see the phone is in charging mode
Ray1976
Same kind of usage as you and I also didn't encounter any overheat warning. I know if you push the limit for gaming, likely it will throttle due to the thin design which ultimately cause heat dissipation to be an issue...but causing overheat warning msg could be due to software optimization need more work. Whatever the case, don't expect a phone this thin to perform great for resource intensive apps like games or equivalent.
Jhyun
No issues using the magnetic airvooc charger. Or did you mean the magnetic power bank ?
Ray1976
What car unit you using to connect to AA? Try to force stop the software in your car unit and open again. See if that helps.
Ray1976
Maybe you want to remove the back case cover and see if the case is "trapping" the heat.
GlueStik
The weird thing is both N5 have heat warning issue. Me and my wife have different usage pattern and her phone got a lot of warning all the time. Mine have been 3 times. Anyway to disable overheat warning? Sometimes the phone is at most warm also kena the too hot warning.
fool1988
For me, I only encounter heat warning issues when taking photo while displaying on front screen ..other than that never encounter heat warning despite phone a bit warm when multitasking but still manageable as I dont do lot heavy or extreme stuff on my phone
1982-1994
Anyone has overheating issue on sd8g3 phones then? Because I find sd8e chipset to be efficient and cooling
tkte_85
both 8g3 and 8gE are hot chips, owning redmagic phones with these chips with active cooling taught me this fact..
