Google Pixel 9 Pro Fold
GeSteSoh
Thinking of changing from my mous case. Any other fold case to recco?
Am currently using the Atomic Slim case above, but find the protection rather overkill.
Am looking at the Ghostek Covert Case instead (1st image) cos its looking slimmer. Anyone know where to find a Ghostek physical shop?
Sensational
i got this case actually. the covert i got it from shopee but the case is damn bulky with the hinge protector. not very used to so i didn't change it and went back to the mous case
ForumRider
This going to be my longest used android phone.
Still , is there any where I could get privacy glass protector for the front screen?
eric5001
anyone knows where is a good place to sell my pixel 9 pro fold?
i am kind of give up on foldable.. i start noticing the display having issue, with google replacing a replacement phone. I want to change to others.
It still comes with 6 months warranty.
eric5001
I sold my pixel 9 pro fold. So I got left over the screen protector, camera lens cover , Spigen case to let go . Interested?
ForumRider
I have all the accessories already, happy with the thinborne casing, thanks for asking !
ForumRider
Need help. Recently I notice the battery life is getting from bad to worse. It's like dropping 10% every hour. If I leave my phone batt 30% left before I go sleep, the batt will be flat the next morning. I checked the phone settings, nothing wrong leh. How ah?
DigDub
Did you uninstall the safetycore app? Heard it drains battery.
hellhole
https://9to5google.com/android-safetycore-app-what-is-it/
So, what does it do?
In short, “SafetyCore” will be used to power new protection features coming to Google Messages for Android, with other apps presumably using the service later down the line.
Google first announced these protection features for Messages in October 2024. This includes the blurring of images sent that may contain nudity as a part of “Sensitive Content Warnings.” “SafetyCore” processes these messages on-device and while maintaining end-to-end encryption.
Google explains:
Sensitive Content Warnings is an optional feature that blurs images that may contain nudity before viewing, and then prompts with a “speed bump” that contains help-finding resources and options, including to view the content. When the feature is enabled, and an image that may contain nudity is about to be sent or forwarded, it also provides a speed bump to remind users of the risks of sending nude imagery and preventing accidental shares.
These features will be optional, but Google is still installing these two apps as a part of its suite for Android devices with Play Services.
Meanwhile, the “Android System Key Verifier” app will be used for a new “contact verifying feature” coming to Android which will be able to help you avoid instances where a scammer impersonates one of your contacts. Google says that the feature will “allow you to verify your contacts’ public keys so you can confirm you’re communicating with the person you intend to message” using a “unified system for public key verification” that works across multiple apps. The system will use QR codes, as the Play Store listing shows, but won’t be launching until sometime later in 2025.
Confusion around the installation of these two apps has run rampant over the past few months as the rollout has taken place, but, in short, users should not be worried about the installation of these apps. They come directly from Google and are ultimately designed to further enhance user safety.
limmk
An app may be running in the background
